CA air intake
SD Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Topic: CA air intake
    Posted: 21 Jan 2019 at 5:09pm
I put the CA back together. and now the carburetor doesn't suck in air. Yes I cleaned the air cleaner, in fact I removed it, so I could push my palm up against the air intake side of the carburetor. No suction. Any thoughts?
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 5:23pm
My first thoughts are a rag or some other obstruction between the carb and intake assuming it was ok before you tore it down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 5:32pm
compression check is in order...Wink
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 5:32pm
valves setting or you have the cam out of time... ???
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2019 at 9:07pm
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 6:53am
My first question to my self would be, What all has to happen in an engine to draw air into the cylinder chamber thru the carburetor? Knowing that will give a clue. When the pistons go down the chamber fills with air regardless where it might come from. Wanting it to come only thru the carburetor all other places air might come in then must be closed tight. I would then ask what is not closed tight check each one. The first would be fit of rings between the piston and cylinder walls. The second one would be head gasket sealing around the cylinders and the firing chamber. The third would be the exhaust valve being closed and sealing tight with the intake valve open. The fourth would be the manifold gasket sealing between the head and the manifold.
The next question would be how to check these in the above order. Some has to be checked on assembly or before. The valves can checked for closing with the valve cover off and checking that two valves are closed with the flywheel on the TDC line. With out compression you will not find the compression stroke. However any time the flywheel is on TDC two pistons are on TDC and you can find one of them with both valve rocker arms in the total up position. Those two need to have the .010 to .012 space between the valve stem and the rocker arm. That will be true with each cylinder.
The above is all well and good if the timing marks on the crankshaft and timing gear were not mixed up at assembly with the mark for the governor.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2019 at 4:08pm
Did you put a new gasket on where the carb meets the intake manifold?  If it's leaking, it could suck air at that point rather than at the carb itself.
