CA 3-Point Sickle Recommendations?
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA 3-Point Sickle Recommendations?
    Posted: 10 hours 22 minutes ago at 7:52pm
Considering a sickle mower for road and ditch trimming.  Prefer 6 or 7 foot.  No experience, what's a good RELIABLE recommendation, esp brand wise?  Not a situation of wanting a native or fixer upper unit at this time.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 44 minutes ago at 8:30pm
no brand, just a comment.. I have an old 1940  Allis sickle mounted on a B tractor.. Works OK... but it would be nice if  you could angle the bar and cut on slopes and hill sides... The old pitman arm type you can only tilt a few degrees from horizontal... Some models are belt drive out the the bar/ cam shaft area.. Those you can tilt quite a bit ... Something to keep in mind..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 16 minutes ago at 10:58pm
Buy an AC  82T trailer type is best bet. Easy on and of. Cut in almost any position. Use one around our pond. Works Great! Tracy
This page was generated in 0.139 seconds.
