c front pedestal questions.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: c front pedestal questions.
    Posted: 27 Apr 2012 at 4:27pm
thinking of tearing into the c to figure out why the pedestal has so much slop in it. it feels like there is way to much backlash between the gears. also, you can turn the wheel much further one way than the other. is that normal?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 6:37pm
I can understand too much backlash making it loose but it seems that if it turns more one way than the other, then one of the arms were maybe put on a spline off or something. Could be on the steering gear or the pedestal depending on what year and style the pedestal is. Just a guess.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 6:41pm
Yes. The gears can get off a cog if someone is not careful during re-assembly. I have been a someone before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:29pm
that's what I was thinking. I'm curious why its so loose.
This page was generated in 1.400 seconds.
