c clutch 8 1/2" or 9" |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4070 |
Topic: c clutch 8 1/2" or 9"Posted: 25 May 2022 at 9:27pm |
the clutch is on its way out on my i wanted to order a clutch and have it here before i took it apart, is there to tell if it is 8 1/2" or 9" without splitting it ?
Rick
Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3695 |
Posted: 26 May 2022 at 4:28am |
The "C" Allis should have the 8 1/2" clutch unit in it...I've never saw anything else in them besides that unit...I think only the early "B's" had the 9" unit in them...
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Thanks(1)
Posted: 26 May 2022 at 6:18am |
If it has electric start, it MUST have the 8-1/2" clutch. Only crankstart tractors can fit the 9" clutch into the bellhousing with the size of the flywheel. This applies to B,C & CA tractors. Crankstart tractors can possibly have the 8-1/2" either by just useing the 9" pressure plate or redrill the flywheel for the smaller pressure plate. I've seen a lot of Crankstart tractors with a 9" flywheel and pressure plate with an 8-1/2" clutch disc.
Edited by PaulB - 26 May 2022 at 10:16am |
HudCo
Posted: 26 May 2022 at 9:22am |
thanks you guys, i will go ahead and order an 8 1/2" this time of year its hard to get my own stuff close to the shop for very long
Rick
Posted: 26 May 2022 at 12:39pm |
At the end, all of the B/C/CA's had the 8 1/2" clutch unit in them...yep, all of the crank start were 9" on the B's for sure
