Bolt size for flower pot hubs |
Joe(OH)
Joined: 11 Sep 2009 Location: Montezuma, Ohio Points: 999 |
Topic: Bolt size for flower pot hubsPosted: 05 Nov 2025 at 12:31pm |
Anyone know what size bolt to put flower pot dual hubs on? I plan on installing a set this weekend and was trying to be lazy about determining bolt size. Thanks!
Life is simpler when you plow around the stump.
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1569 |
Posted: 05 Nov 2025 at 9:39pm |
Couple self tappers oughta do it.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4156 |
Posted: 06 Nov 2025 at 5:47am |
Joe, I don't know specifically but a lot of dual hubs use 5/8" bolts/studs. Fine thread most times, 18 pitch I believe. The ones that mount the hub to the center could be 3/4" maybe?
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4557 |
Posted: 12 Nov 2025 at 11:13am |
It's been a lot of years since I put mine on my D21. Likely 3/4" to mount the bub to the center. There are two different sizes of studs to mount the dual to the hub.
plummerscarin
Posted: 12 Nov 2025 at 12:39pm |
Guess I will need to take a closer as I plan to move them to another tractor. I did see they are carriage bolts and appear to be 5/8”. As for length, will get back to you on that
plummerscarin
Posted: 4 hours 44 minutes ago at 6:22pm |
Ok, I know it's late to the party but here it is:
On our tractor the flower pots are held on with ¾"×3½" grade 5 carriage bolts |
