better headlights on them dang Fords,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: better headlights on them dang Fords,,,,,
    Posted: 14 Dec 2024 at 9:33pm
   On my new to me F150 it has got to have the most pizz poor headlights that I have ever had to drive behind,,,!! I been doing a lot of reading and the trks either came off the  assembly lines with HALOGEN OR LED lights. mine are Halogen.
 A lot of the owners are changing to either of 3-4 types that involve some sofisticated changes that I do not even want to try. Some guys are able to get theirs to work and some wind up frying the trk ECM.  The alternative is to dish out $1800 for headlights,,,,
 My understanding is that a simple bulb change does not do any more for your trk's lights than what is in there now,,,,??
 Anyone  done any of the modifications and had good luck with them,,??
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 10:00pm
D Joe, are your lens nice and clear, if U can't see bulb they need cleaned? Any big box store or auto parts store should have at least 1 brand of "headlight cleaning kit" on the shelf. An hour or less on each can make a big difference.
 My farm truck a 2001 F150, 300K+ that sets outside has needed the lens cleaned and polished a couple times. It makes a lot of difference in light output. I've never ran any head lights other than OEM halogen in car or truck in 40 years.
 I have considered a LED changeover for hi beams mostly as a counter measure for the A-holes that don't dim theirs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 10:28pm
 Hey Chris,,,YES,,I cleaned the lens just a week or so ago,,,but they were really ok as they were,,!!  From what I've read you cannot just change to LED bulbs from the Halogen bulbs,,,or have you read differently,,?? I hope so,,,!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 10:50pm
joe, i think the new LEDs interchange with the Halo in most applications...You can buy LEDs that are equal to the Halos, or you can buy SUPER BRIGHT ... You want a 6500 type to get a pure WHITE light i think is what your looking for..
I would read up on one of the sites... then call or e-mail these guys and ask a few questions...  That being said, the Halos are suppose to be very good lights from the factory.
Edited by steve(ill) - 14 Dec 2024 at 10:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 10:56pm
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2024 at 11:55pm
Wonder what happened to the old 5.00 buck sealed beam that was good enough for almost a hundred years?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 3:47am
  Hey Walker,,,that right there is a Great Big 10-4,,,,and you never had to polish them sealed beams ,,,ever,,!! I often wonder whose kinfolk it was that convinced the MFGRs to switch over  to these POS'sss,,!! Another of Ford's "Better Ideas",,,,,My Son's F150 has the LEDs from the factory and it is like Day and Night,,,just NO comparison,,!!
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 4:26am
I bought 9005 and 9006 Led replacement bulb kit from Amazon. They go right in place of the original halogen bulbs connect directly to the existing wiring. On my old suburban they made a difference. I also changed out the complete headlight assemblies on my other suburban. An aftermarket clear lens kit for all the front lenses and the rear lights was cheaper than one light from Chevy. They lasted 10 years before they started to get hazy like the originals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 5:57am
Everyone went to plastic headlights cause.....
It's cheaper for them to make, saves MPG, and krap out sooner so more visits to the parts counter.
'they' win,win,win...YOU lose,lose lose
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 6:48am
I replaced BOTH headlamp housings on my 99 due to Yellowing and deep clouding, could not see with headlamps very well at all, now are back to Bright, Same Style lamps inside them as the old ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 8:51am
 Hey Dakota,,are the 9005 and the 9006 numbers for the brights and the dims,,?? I've looked at so danged many different ones I've lost count,,, I'm now leaning towards some from Sealight that Steve has sent a link on as suppossedly they are changeouts with NO wiring mods required.
 I am still kinda concerned about some "canbus" ECM potential issues that has caused some owners real issues ,like a "Warning" notice on dash,,,,,,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 8:58am
 Hey Dave,,,did the new headlight "housings" you bought come without  the rest of the headlight assembly or were they a complete unit?
 I would be very interested in the housings alone IF they are available  as the PO  had  polished the lens so many times they now are etched on inside from maybe too much heat while polishing,,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2024 at 11:41am
Got mine off Parts Geek, Package Deal Lamp assemblies and TS Lamp assemblies, just had to install them.
My old ones beyond the Clouding also had degraded the Back Reflector Silvering, not much chance of fixing that.
Edited by DMiller - 15 Dec 2024 at 11:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2024 at 12:26am
D Joe, I'm thinking of using the style Steve posted. They just twist in the hole in original housing.
 That's IF I spend the money for them. I see that to change them on my newer truck, I'd have to partially loosen the plastic front fender liner to get to the rear of lamps or remove entire grill and then remove the lamp assemblies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2024 at 3:49am
 Hey Dakota,,On the " Aftermarket Clear Lens Kit" you bought for your Suburban,,,
  #1  where did you buy these?
  #2. Is the "outer" clear plastic lens available by itself for the headlights? I'm talking about the clear lens that you have to keep polishing due to fading,,??
   #3  Mine are now etched due to PO using some heavy handed polishing and I think he must of got the plastic TOO hot,,,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2024 at 4:00am
  Yeah, Chris,,I'm thinking to go with that same kit. I did talk with one of Sealight's agents yesterday but he was more interested in going home than talk specifics with me,,,!!! I'm try calling Sealight again today. I also looked in Amazon for (I Think) the same Sealight  LED bulbs of the SAME specifics that Steve quoted and are much less than the price that Sealight offers off their website,,,?? I think those are the ones that Dakota got for his Suburbans,,,,???
The Sealight rep told me the warrantee from Sealight is only ONE YEAR,,,?? Gonna check Amazon's warrentee,,,,?
Edited by desertjoe - 17 Dec 2024 at 4:01am
