B Transmission and Final Drive oil
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Topic: B Transmission and Final Drive oil
    Posted: 19 Oct 2019 at 3:27pm
I have a reprint of the Operating Instructions / Maintenance manual for my B and it says SAE 20 in the transmission and differentials and im thinking of doing a fluid change.
What do you all use? Would 10W-30 engine oil be good for it? I'm thinking probably don't want too thin though, right?
Thanks all...
BenGiBoy
'39 Model B
Tractors are cheaper than girls, remember that!
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 5:16pm
I use SAE 20 in mine, but I think most folks use universal hydraulic/transmission fluid.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 5:27pm
I use universal hydraulic/trans fluid. If you B has hydraulics (not all did), I wouldn’t use 10w30 motor oil.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 5:33pm
I use 8 quarts of UTF in the trans / hydraulic/ bevel gear box , and 80-90 gear lube in the final drive drop box pan on each side.. Takes less than a quart on each side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 8:23pm
Mine just has the PTO, no hydraulics.
Okay. Thanks all!
Ben
'39 Model B
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2019 at 10:46pm
keep in mind that SAE 20 weight, if i'm not mistaken is non-detergent
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 11:50am
Nothing but Universal Transdraulic Fluid in my tractors.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2019 at 6:05pm
When we sold them newin the 30's to 50's we used NON DETERGENT SAE 20 wt oil.  It worked fine.  However, I have heard good reports on the UTF type oils.
In the final drives we used 140 but again there are better lubricants out there now.
Take good care of my favorite.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 3:28pm
Okay. I'll put something in it then, it's probably not super particular i'm getting the idea. Smile I'll let ya'll know what I use...
Thanks all!
Ben
'39 Model B
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 4:28pm
Just don't use a Detergent Oil in the Hydraulic.
Apparently it will foam up.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2019 at 5:52pm
Gary
That makes sense, hydraulic oil probably has anti-foam agents or something in it.
'39 Model B
This page was generated in 0.688 seconds.
