B throttle
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: B throttle
    Posted: 12 Jul 2026 at 7:52pm
The throttle on my b does nothing till 1/2 way up the quadrant. I read somewhere that when this happens is because the spring above the governor is loose and to bend the lever until the spring is tight , Then that should solve the problem?
If I do that, will it increase the full throttle rpms?
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2026 at 6:40pm
its possible the governor rod is off with respect to the carburetor... but FIRST, loosen the square lock screw holding the throttle rod to the throttle handle, and pull the rod BACK 1/4 inch and relock... and retest..
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2026 at 8:21pm
Mine does not have the square head set screw. It has a threaded piece, looks home made. The threads looks sketchy. I guess I could drill the threads out to fit the rod and drill and tap for a set screw.
Was going to send pic, but it says too large
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2026 at 10:52pm
i would do something with the rod length to arm and see how that works.
this site will take up to 2 MB photos.. Too large for me... If your on a computer, open the photo is PAINT and shrink to 800 x 600 pixels... if your on a phone, send to yourself, then RESIZE to get down around 100 kb.... Most cameras these days are taking 5 MB photos.. at 5000 x 4000 pixels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2026 at 10:58pm
most of the factory throttle assemblies i have seen look like this... they have a piece of wire thru the hole where the ROD goes and the LENGTH is adjustable... SOMEHOW you need to shorten the rod length to the governor...... and see if that helps..
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 6:41am
Best picture I can get. You should be able to see what it is by enlarging it. Someone welded a rod to the original rod.
Edited by john2189 - 14 Jul 2026 at 6:42am
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 9:21am
For maximum RPM's the rod has to be pushed forward as far as it can go. There should be  a "stop" on the governor spring arm to keep it from going too far.
Edited by DrAllis - 14 Jul 2026 at 9:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 9:59am
yea, DR  is right... the rod should be LONGER, not shorter... try disconnecting the rod and push the ARM on the GOVERNOR further forward and see if that is the problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2026 at 10:29am
yea, DRĀ  is right... the rod should be LONGER, not shorter... try disconnecting the rod and push the ARM on the GOVERNOR further forward and see if that is the problem..
Ok there are enough threads to make it longer. Im on vacation now so when I get back I will try it
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2026 at 5:59am
I looked at the throttle yesterday and I decided to leave it alone.
It has full speed, just nothing at the lower half of the quadrant.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2026 at 6:21am
And that is the way some of them are. Those engines are used in other applications and sometimes have different governor springs/governor spring lengths. If 100% full speed can be achieved, what's on the other end of the throttle lever stroke means nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2026 at 10:31am
I have a Woods l59 mower on it so it has full speed to run the mower. That is all I use it for.
'41 Allis B
'49 Farmall Cub
