B questions |
Mark in Iowa
Topic: B questionsPosted: 02 Oct 2012 at 7:28am |
I have a '39 B crank start , 2 questions:
1. When I cold start it I have to have the throttle lever almost fully forward and it takes a lot of cranking to get it to pop. Help? When it starts it surges and then levels off.
Note, the mag has been timed, good plugs, carb rebuilt, gas tank cleaned out.
2. When pulling a load and the engine boggs down if I pull the throttle lever back and push forward, then the governor opens up and the engine reves to the needed rpms? help
As always thanks for your help, Mark
KenBWisc
Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1186 |
Posted: 02 Oct 2012 at 8:14am |
Your governor isn't responding.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 02 Oct 2012 at 11:28am |
The surging can be cured by the use of a surge suppressor spring. It goes from the throttle rod connected to the carb up to a manifold stud.
