Australian built grader
Listo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Listo Quote  Post ReplyReply Direct Link To This Post Topic: Australian built grader
    Posted: Yesterday at 7:30pm
Chasing info on Australian built forty five with the supercharged 516 engine and pressure feed gearbox .
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 21 hours 18 minutes ago at 2:33am
What info?
I nursed a 1959 one back to going.  Posts on here start  back maybe 15 years and have tapered off since.
Last one I recall was responding to a bloke who needed information on access the power steering unit.  Caused the thought that I might have been the only bloke in the world who had been in there in the last 15 or so years.  Now there are at least 2 of us.
IIRC the Oz model number is 124 which you won't find in AC part books of the era.
Edited by Ian Beale - 21 hours 9 minutes ago at 2:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Listo Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 27 minutes ago at 1:24pm
Gday Ian Beale , I have s/n 524/112 . Got it running last week but broke a chain 100 m from where it sat for a few years . Got it onto the drop deck and off then up a good hill to the workshop but after a day cleaning up pto controls and shafts I found the a few nasty bits in the gearbox drain hole . From what I can work out from a 45 Australian parts book is it must be high and low with reverse on one stick then 1-2-3 on the other . Has an oil pump on the top shaft of gearbox . Have you seen that as the 45 manual didn’t have it or the ad40 one I found .Appartently 5500 hrs on it , all gauges look genuine and generator still charging , came from Emerald- gemfields way over to near Miriam vale 14-15 years ago . I have fiat dozers so I know the most likely parts supplier but you haven’t seen any about for a gearbox and a brake assembly . Thanks
This page was generated in 0.289 seconds.
