Antifreeze
Acguywill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acguywill Quote  Post ReplyReply Direct Link To This Post Topic: Antifreeze
    Posted: 9 hours 37 minutes ago at 11:36pm
This may be a dumb question but can antifreeze settle out? I have an old nat gas powered pumping unit that has been sitting in the barn for the last 4 years. Before I parked it I changed the oil and antifreeze and then ran it for a few, maybe 10, minutes. I pulled it out a couple weeks ago and the antifreeze in the rad was slushy close to solid actually. I opened the drain on the block and it was fine. Put it in the heated shop and let it thaw out and took a closer look at it today. Antifreeze from the top of the radiator tested good to -8 celsius and the first stuff out of the block was good to -40. I mixed it all back up and it tested good to -29 which is about what it would have been when I put it in. How is that possible?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 53 minutes ago at 6:20am
Never heard of that, never given it much thought. I suppose it's possible? It may not have mixed completely in the short run-time?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 45 minutes ago at 6:28am
That initial 10-minute run time was not enough to thoroughly mix it.  You should have run it up to temperature so the thermostat opened and kept it there for at least 10-minutes to circulate and mix the entire system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 7:42am
Especially if you dumped in a gallon of straight antifreeze and then a gallon of water and then didn't allow it to reach operating temps (open thermostat).
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 20 minutes ago at 7:53am
I always premix 50/50 in a five gallon bucket coolant to distilled water ratio with ethylene glycol. Have never seen it separate in the past. Typically I use "Prestone" for automotive use and "Fleet Guard" in low silicate formulation for industrial and truck engines.
That's All Folks!
This page was generated in 0.176 seconds.
