Another parts help post
brews4me View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brews4me Quote  Post ReplyReply Direct Link To This Post Topic: Another parts help post
    Posted: 28 Dec 2016 at 4:42pm
1958 D14
I need a 220873 PIN, or a few, Drawbar guide. Part # 5, 3/4 diameter
In town all i had to try was Ace Hardware, they looked at me like I was crazy.
Does anyone know where these can be found online???
Post Options Post Options   Thanks (0) Thanks(0)   Quote brews4me Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 4:43pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 5:19pm
McMaster Carr has a number of different clevis pins to pick from. If you are not looking for an exact match, a pin can be made from a 3/4" grade 5 bolt. Use a bolt with the unthreaded shank long enough to match the pin length, cut the threads off, and drill a hole for the keeper pin where needed. I have tightened a couple of these mountings by truing the holes with a bur bit and making pins from 7/8" bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 5:36pm
I don't see nuthin wrong with the one in the pic.  What's the problem?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2016 at 8:47pm
I have my local fab shop make some up whenever I need them (usually when another tractor arrives in the yard).
Post Options Post Options   Thanks (0) Thanks(0)   Quote brews4me Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 12:56am
missin one
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 6:02am
MinnParr   $20.00
Gary
http://www.minnpar.com/partlisting.asp?PartNbr=70220873
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2016 at 10:12am
I've picked them up at Hutch and/or GOTO in the past. Lad Benes I believe has had some in the past at these shows. Forget what he posts under, be he is on this site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brews4me Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2016 at 9:21pm
Found a few in Ill from a member, Thanks all!
