Aluminum radiators
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: Aluminum radiators
    Posted: 01 Jan 2025 at 7:59am
Thinking about purchasing an aluminum radiator for my 7040 off EBay. I’m assuming it’s made in a 3rd world country which is too bad. I purchased one for my 31 model A pickup with good results. Just wondering if anyone tried one on a 7000 series and is willing to offer an opinion. Happy new year!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 8:28am
Get your old one recored locally - it will be good for another 50 years.  If there is a problem, they will stand behind their work.  E-bay won't.  I don't see the need for an aluminum radiator either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 9:05am
I agree STAY away from FLEABAY for anything. No matter what it's buyer beware.
I wouldn't know about what you might get for a 7040 radiator. Although I did get an aluminum radiator (not form Fleabay) that was to fit a B,C,CA primarily for the loss of weight for the CA I was pulling then. The workmanship of the radiator was very good, however somewhere in the engineering of changing the dimensions in inches to the workers millimeters something was lost, the fit was terrible. There are much better radiators available for the same money or even less.
I would have concerns about and aluminum radiator in a field tractor.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 9:36am
Would agree stay away from aluminum radiators for a tractor that will see the field again. If you poke a hole in it or stress crack it there's no possibility of a soldered repair, granted "BARS leaks" or black pepper could get you out of a bind still but they're only a temporary fix.
Don't think there's any reason to go with aluminum either, save for weight savings/making shiny. The original radiator recored by a good shop will cool plenty enough.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 9:50am
I've had 2 7XXX radiators recored. No regrets.
If you have a good shop nearby, I'd go that route.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 10:39am
 I think all the newer tractors have aluminum rads? My 2003 New Holland TG230 is aluminum. Had to take it out to clean it out last year. Previous owner had used a power washer to clean it out, did a bad job washing it out. Hard to find a radiator shop that would clean one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 10:40am
And yes, i would only trust one from a reputable local radiator shop
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 11:02am
Bought a new radiator for my 7060 from Northern, ( Willmar, Mn.) been good so far and about the same cost as a local shop quoted for a recore.
WD,D15,190XT,7000,8010x2,7060,8070
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2025 at 2:32pm
Most likely they do now, less vibration and better protection on modern units not to mention the cost saving for manufacturers.
The most effective and inherently repairable rads are still copper/brass.  Not saying alu wouldn't work, but longer term more likely to need replacement or at very least taken in for any repairs that could otherwise be done by "Joe Blow" with a blow torch & some patience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 10:37am
My Radiator man always used to say Aluminum Radiators suck. They always fracture in the corners. I've had a couple of em' in my hotrods, and I had one do just that. Start leaking in one of the corners. Coarse, when I took it out and had him fix it, he was always like "see I told ya so". I would be a little nervous about sticking one of those in a working Tractor unless they make em' much better now than they did years back. I have one in my 26' T coupe right now, and so far so good. I better not say anything. I'll probably go out to the barn and they'll be a Green puddle under the car....  LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 10:54am
I think this request is going in a "pulling" tractor. I don't know why he feels the need for an aluminum radiator in a tractor that is going to pull in a weight class that doesn't need to lose weight in that area. But, it's his money.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2025 at 6:16pm
I have a 34 year old tractor with an aluminum radiator, used a LOT, no radiator problems ever….probably will wish I hadn’t said that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 5:32am
Hard to find a good radiator shop around any more- the ones I see Id go for it, deffinetly cheap enough
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 6:12pm
It just depends  on million little things. Still running 2 Ford Ranger pickups 98 and 2000. I think 3 cheap aluminum radiators replacements on the pare.  So a total of 5 to get them to about 600,000 miles on the pare. But at NAPA it was $120 a piece (pre covid) and it was there the next morning.
Have New Holland 912 swather with Ford strait 6 gas engine, about a 1970 model. It needed a new radiator. No local radiator man, so sent if off $1400 to recore it, or over 2000 for a new one.Confused If only I had thought Wink, stack 2 of the cheap aluminum ones in there.LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2025 at 7:51pm
Doug is right. It's tough to find a good Radiator man anymore. The two guys that I had were a little older than me, and both of em' retired. That's why I went for an Aluminum unit for my 26 T' Coupe hotrod. We'll see how long I go with it. It's built for a small block Chebby, so it should keep the 4 banger Mercruiser engine cool....
Steve@B&B
Chananain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chananain Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 5:48am
I put an aluminum one in my WD45 a few years back and it's been holding up great. Fit was decent, just had to tweak the mounting holes a little bit.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 7:19am
There are different grades and quality of aluminum for both charge air coolers, and radiators. Ebay, Amazon, and the like are not the place to purchase and expect decent life expectancy. You get what you pay for in this arena. You want quality, you got to pay for it.
Try these folks. They used to do custom work and their work is top shelf. Not the cheapest by far, but the products do hold up well and they will stand behind it:
Edited by Codger - 24 Apr 2025 at 7:20am
That's All Folks!
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 9:25am
So far I have had good luck with Northern brand. Doesn’t fit exactly like original, but pretty well. Would prefer re-coring, but if i have to replace, I would buy Northern again.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2025 at 11:16am
griffon radiator link did not work.  try this link.  http://griffinradiator.com/
Oldwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldwrench Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 7:00am
I can second Griffin radiator as a top notch company to work with.  I had the radiator go out on a SAME tractor, and it was impossible to find either a salvage or NOS replacement.  I sent the old radiator to Griffin, and for $800, I got back a perfect replicate, in aluminum, of my original, that bolted right in place.  I told a neighbor about them when he needed a radiator for his 190XT.  He used them, and was very pleased with the results.  My radiator was a very heavy aluminum with beautiful welds, and no leaks after 5 years or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 8:50am
Oldwrench that's amazing.  $800 scratch built replica is a bargain in my world.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2025 at 11:33am
all aluminun radiator ?   or one with plastic tanks crimped on ?   the problem is mostly with the plastic tanks
This page was generated in 0.111 seconds.
