Allis G quits after a minute or so, then restarts
Mike Rock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Rock Quote  Post ReplyReply Direct Link To This Post Topic: Allis G quits after a minute or so, then restarts
    Posted: 19 Oct 2026 at 2:13pm
New member,
Age old question.  I have a G that runs a few minutes, then quits.  It restarts, runs and then dies.  When it does run steadily, if I apply a load, by dropping the tool bar and engaging discs or cultivator shanks, it dies.
It ran great all summer, with a few issues.  Now I need to lay out beds to plant garlic and it's acting up, again.
Thanks and God bless,
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2026 at 4:53pm
my fuel filter was plugged on a small engine and it did that.. kept running out of gas if you loaded the engine or ran much time at high idle..
Check fuel flow, check carburetor float setting, drain bowl if possible ( crud).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Rock Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2026 at 5:53pm
Earlier, I pulled the carb.  Little bit of white residue from the tank.  Then I took the carb apart....  cleaned, nice.  Then I took the sediment bulb off...lots of white sediment.  THEN I noticed the screen was dirty.....took it off.....and found a second screen underneath the first.  Really dirty and white.  No wonder I had no steady fuel flow, an air bubble formed between the screens.   Waiting for gasket cement to tack dry before reassembly.  I feel pretty confident the screens were the issue.  The problems started to slowly get worse after the carb was rebuilt last year or the year before.  Let's hope.
Thanks for the tip, it reinforced what I think I found.
God bless,
Mike
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2026 at 7:40pm
I'm sure the "correct police" will not agree, but an inline fuel filter works wonders on some of these old tractors with a little rust in the tank. When I put in an online filter, I take the screen out of the sediment bowl.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2026 at 8:29pm
every one of my G’s has a magnet on the bottom of the tank near the cutoff
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
