Allis G piston stand out question.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Topic: Allis G piston stand out question.
    Posted: 12 Mar 2012 at 10:28pm
Well i am back on the Allis G engine and finally completely took the engine apart.
the pistons stand above the block at least .064 i measure this with a feeler gauge.
I think the pistons are hitting the head causing a knocking noise.
Question is there anything i can do with this block?
I have extra block laying around and notice those pistons only stand out just above the block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 12:58am
I had this problem with my WD45 Diesel. I took the pistons to the engine machineist and had them machine .020 off the head of the piston and the knock went away. This made me vary happy since i was trying to figure out  what was makeing the knock for 2 years.                                Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 8:53pm
Thanks Matt
I wounder how the top ring or the piston will hold up by machine off the top of the piston?
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:49am
Perhaps a "poor boy" fix is stacking 2 head gaskets? I would definitely copper coat, or light application of lithium grease between them if going this route. Kip
