Allis G hydraulic pump |
Scott(GA)
Joined: 13 Sep 2009 Location: PeachtreeCityGA Points: 407 |
Topic: Allis G hydraulic pumpPosted: 10 May 2011 at 9:34am |
Well... The Bad News: The first problem is the lists are Bass-akwards. They are listed in groups - the groups are the individual bearing manufacturers. Then, under the manufacturer's group, they list the part in numerical order BY THE MANUFACTURER'S NUMBER. As a result, I have to scan through several pages of poor print with dimming eyes blah, blah, blah... The Good News: I haven't gone through the whole list but I have found one! Rollway W-919 Allis-Chalmers 800736 Best regards, Scott |
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 10 May 2011 at 9:05am |
Scott, The real question is ... Do you have the crossover for the bearing on the other end of the shaft? Number 800736. Thanks
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 09 May 2011 at 8:18pm |
we have a used one or can get a new one your choice a phone number would help for a quicker response 1-800-254-3116 for a reply over nite delivery if wanted we have crossover for all A-C bearings
Scott(GA)
Posted: 08 May 2011 at 10:08am |
I have an Allis-Chalmers Part Number Bearing Exchange List in the front of my A/C Master Parts List:
AC Part Number - 800735 New Departure - 43303 or 43308 print is not good but I'm pretty sure it's 43303 Best regards, Scott
norm[ind]
Posted: 07 May 2011 at 4:59pm |
it is a ndh bearing looked this morm all info. at shop puter at home 1-800-254-3116
will check availability wth a snap ring
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 06 May 2011 at 9:23pm |
Charles, I feel your pain. Been there done that. Tracy Martin
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 06 May 2011 at 8:22pm |
Take A caliper and measure i.d. and o.d. and width then check style . You can look it up on computer. I bought four bearings for trans mission for finish mower for 36 dollars including freight. Shop around .Most come from China anyway.
norm[ind]
Posted: 06 May 2011 at 7:20pm |
we have crossover to the bearings will check
Charles (KY)
Posted: 06 May 2011 at 7:15pm |
Unfortunately this bearing was a Allis only bearing. The old bearing is not the correct bearing. Several of the bearing in the allis G hydraulic pump were Allis only bearings. Local bearing dealer cannot cross it over. Hopefully SandyLake can help tomorrow.
Tedin NE-OH
Posted: 06 May 2011 at 6:28pm |
Call Sandy Lake Implement 1-888-252-0656
Tedin NE-OH
Posted: 06 May 2011 at 6:08pm |
If you have the old one, read the part number off the bearing and go to a bearing distributor. Most of Allis Chalmers bearings were standard issue.
Charles (KY)
Posted: 06 May 2011 at 5:57pm |
I am trying to find a bearing either new or used or a picture of one for a Allis G hydraulic pump. The bearing number is 800735 and is item #4 in the parts diagram. Any help would be appreciated.
