Allis g engine
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Topic: Allis g engine
    Posted: 25 Jun 2022 at 11:16pm
Hi all I am trying to get a engine for my G running it was meant to be a runner I have a good spark and when I tip some gas down the spark plug hole and hand crank it all i get is flames out the exhaust were do I go from this point and what do I try next .
Tractors Allis EB,two C,diesel G
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2022 at 5:35am
It sounds, to me, like your timing is way off, maybe even 180 degrees?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2022 at 9:04am
I agree, sounds like timing is off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2022 at 10:01am
Also, be very careful hand cranking if you aren't sure the timing is right. When it sparks at the wrong time, it could easily kick on the crank and the crank could hit you. There have been MANY broken arms from cranking an engine that is slightly out of time.
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2022 at 10:19pm
Hi all I think I have the timing about right no flame out the exhaust it now puffs smoke and sounds like it wants to go. a bit more tinkering and I should have it running
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 12:05am
Hi all I am as happy as a dog with two tails I have been able to get this little G engine to run and it runs smoothly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 5:15am
Was the problem the timing was off?
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2022 at 3:07pm
Yes it was out by 180 degrees and a new set of spark plugs
