Allis FWD 8050 Powershift Issues
devbow76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Topic: Allis FWD 8050 Powershift Issues
    Posted: 11 Nov 2025 at 9:28pm
Got a good one for you guys. Tractor quit moving so the powershift was pulled and hauled into the local dealer for a "rebuild". Got it back and installed it in the tractor. Worked for 5 hours then quit again. Dealer wouldn't warranty because they just got the powershift and not the whole tractor so we decided to split it. Found that there was multiple piston seals ripped. Replaced all the seals and reinstalled in the transmission. Its been working for over 50 hours now however its developed a random problem. It will be driving and happens in any range or powershift. It acts like someone shifted the transmission into neutral and it just coasts to a stop. The range and powershift were not moved nor the clutch pressed it will be driving just fine and then coast to a stop. If i mess with the range/powershift it will start going again. Sometimes its 5 minuets and sometimes its 45 minuets. Removed range transmission cover and when it acts up all the range gears stop turning but you can still hear the hum of the clutch drums turning so I'm convinced its in the powershift somewhere. Also when it acts up the steering, brakes, and pto all still work just wont move. All clutch pressures are perfect to spec when it acts up as well. Any ideas are greatly appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 7:23am
Ripped or cut piston seals on one of those transmissions is the mark of someone who has never done one before. You have a hydraulic problem. Does the 1800 RPM light on the dash work?????????   I assume not. Get it fixed so we can diagnose what is going on. Was the Power Shift valve disassembled and gone thru ???????? Again, I assume not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 10:04am
Sorry for the late reply I'm not very tech savvy. Checked pressure at all 1/8" pipe plugs for the a,b,c,d clutch's and when the tractor stops moving. Each clutch pressure does not drop. Stays good at 210psi which according to the manual is the correct pressure. Doesn't matter if the oil is cold or hot the result is still random. When the tractor stops moving with the range cover off of the top of the transmission. The gears stop turning but i can hear the hum of the powershift clutch packs still turning. It seems like there is a disconnect from the range transmission to the powershift. When i seen it split it looks like there was only a collar connecting the two but the splines were in great shape and there is no grinding noise at all when its driving or stopped. When i shift the powershift gears i can hear it shift in the powershift. rpm light on the dash works and does go out when required. Powershift valve was gone through and also replaced as the dealer had the parts cannon out .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 11:12am
Well, you've determined the PST seems to be working. The range transmission can't if it isn't turning. Has to be coupler related, but how can it re-couple itself ??  And how can the output shaft to the PST just quit turning and then decide to start again ?? Sounds like a split it (again) in the future. If that coupling isn't bad on the front of the range tranny, then it must be in the PST but I'd have no idea what. Somebody has to be first. You're him.               EDIT:   I don't have my service book in front of me. It only takes TWO of the six clutch packs to make the tractor move forward or reverse. I know the C2 clutch is for reverse. I know the C1 clutch is one of the two "inching" clutches. There is one more "inching" clutch, but I don't remember its name. Anyway, both inching clutches are applied in 3RD gear. To fully diagnose this, I guess you need at least 5 test gauges all hooked up at once. C2 is only for reverse, so you might be able to skip that one. This has to be a hydraulic problem, and proper diagnosis is crucial to a good outcome. Love to help. Wish you were closer. Someone has missed something in the valve itself or the hydraulic application of clutch packs.
Edited by DrAllis - 12 Jan 2026 at 12:40pm
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 3:25pm
This may be out of left field. Just thinking of anything that might help. It semms to me the inching valve is dumping pressure on the clutches causing the tractor to stop. Sinc you have had it apart i think id go through the procedure to adjust the inching valve to factory spec. That thing is sensitve and it doesnt take much to throw it off. You may have slready done that i dont know. Trying to think of anything to keep you from having to split it again
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 3:58pm
I will take any help at this point. My only question to that is i should see the clutch pressure in the a,b,c,d port drop shouldn't I?
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 4:03pm
Ok i also agree that it seems the powershift is working but i find it weird how the coupler could come undone and then slide back on. I was wondering what connects the input shaft from the engine to the range transmission. Does it go flywheel clutch pack then output shaft of powershift, then coupler, then range. Like what's the path of power maybe that'll help pinpoint this. I would like multigauge set like that but i only have a single gauge set as the multi is pricy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 4:06pm
I would also like to add the powershift pump has been flow and pressure tested passing with flying colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2026 at 10:07pm
Actual clutch pressures will vary with oil temps and engine speed. 210 psi is fine. That isn't your problem. If it was under 100 psi there would be a problem.  Place the PST in 3RD gear and leave it there. It is mandatory to have TWO gauges, and a hose on each gauge. Wire the gauges to the head light or battery box or whatever, so that you can SEE the gauges while driving. Have the two gauges plugged into the C-1 test port and A-2 test port. Now, drive the tractor until it quits moving and tell me what the gauges say. The inching pedal absolutely must be fully UP !!  Any downward position of the inching pedal cuts off oil flow to C-1 and A-2 inching clutch packs. When the tractor quits moving, does the red 1800 RPM light come on ??? and both gauges dip to zero ???   *****  The small inner transmission drive shaft goes from the torque limiter disc all the way thru the rear end and powers the hydraulic pumps. You always have power steering, right ??  so there is no problem there. And the larger drive coupler just cannot disconnect itself and reconnect itself. There has to be a hydraulic problem of some kind.
Edited by DrAllis - 19 hours 16 minutes ago at 6:09am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 12 minutes ago at 8:13am
I've only seen one coupler fail on those tractors, in my experience.  It was the large coupler between the transmission and rear end on a 7060 power director tractor. It made one hell of a noise when trying to move. The splines had deteriorated from what I call fretting. The transmission shaft was in good condition, but I had to replace the hollow shaft in the range box. Looking back on it, I probably could have just welded the coupler to the bad shaft.  That 1800 rpm pressure light can be an invaluable tool on those tractors. It can help to pinpoint any leaking clutch pack. I can't believe that multiple clutch packs are leaking. It sure sounds like a drop in pressure or flow that affects the entire transmission circuit. Odd, that it would come and go like that. I have seen the inching spool stop break an ear off and cause weird things, if it gets lodged in the wrong place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 32 minutes ago at 8:53am
Ill go get another fitting as i have enough gauges but not enough of the fittings. drove around yesterday for an hour before it did it. Red light never came on and usually never does. then it did it after 10 mins of driving, very hard to pinpoint when it does it as its so random. Inching pedal does come all the way up and can watch the spool operation is correctly in and out as well as it response to the percent of clutch pedal travel correctly. the first time it disconnected was in reverse and the second was in 4th. Moved the gear shifter from low range to high and it instantly started working again. Second time i moved the range in all different spots as well as the powershift then it randomly started working again. pto and power steering all still work when the tractor stops moving. Does the large drive coupler just connect the powershift or also the hydraulic pumps?
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 29 minutes ago at 8:56am
that makes sense to me that it would make a lot of noise when those spines are grinding away but when the tractor stops its like you put in in neutral. can hear a very slight disengagement then the tractor rolls to a stop without moving the shifter or pedal. i also checked with another tractor it can be pulled when it stops so its not like it locks up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 27 minutes ago at 8:58am
So another question what does the output shafts jobs do on the powershift. like outside shaft vs inside shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 26 minutes ago at 8:59am
Large coupler drives the tractor. Small coupler inside the large coupler drives all hydraulic pumps. That ain't the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 15 minutes ago at 9:10am
ok that makes more clear to me now. I will go test those clutchs and report back. May be while getting the fitting and waiting for it to act up
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 43 minutes ago at 9:42am
Are we 100% sure this isn't a range shifter issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 19 minutes ago at 10:06am
Anything is possible at this point. I have adjusted the cables multiple times even removed and used a ratchet strap to make sure it was fully pulled into the range gear made no difference
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 6 minutes ago at 10:19am
Ok i got the fitting plumbed in and went for a drive. took about 30 mins this time and then same thing coasted to a stop. A2 and C1 didnt drop and both stayed around 240psi when reved up and in 3rd gear low range or high
Post Options Post Options   Thanks (0) Thanks(0)   Quote devbow76 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 52 minutes ago at 10:33am
I have a few days here free so i think im gonna split it before i get to busy. gonna go over everything with a fine tooth comb and let me know where i should look if it isnt obvious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 28 minutes ago at 8:57pm
If I was doing it,  I would get the tractor into the position that I wanted for splitting.  Duals off and drive wheels spun out, if it has that feature.  I would then pull the valve body and go through it. I wouldn't just start splitting the tractor without knowing that the valve body wasn't the issue. Getting the rear wheels moved out is a huge benefit if you have to  split it. If the tractor has the spin out wheels, it's a lot easier to do if the tractor will run. Once the valve body is  off you don't want to put it back on just to move the wheels out.  Hopefully, the problem is just in the valve body, as it is kind of the brain for that transmission. With the valve body off,  you can apply air pressure to the corresponding holes in the housing and see some of the packs engage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 43 minutes ago at 10:42pm
I'd have to verify that 240 psi clutch pressure number. I thought the PST regulator valve pressure setting was more in that 195-205 range (maybe that was Power Director) but anyway, if the C-1 and A-2 inching clutch packs are at 240 psi (maybe a little high) in 3RD gear, they aren't ZERO. So, why does the tractor stop moving ??   And, going back to the very beginning, is this what it was doing originally ???  Forget the cut piston seals after the tranny repair. There's a snap ring on the transmissions output shaft to keep the drive coupler from sliding forward I think ??
This page was generated in 0.091 seconds.
