Allis Chalmers (Fiat) 5050 Lift
CurtisJ74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CurtisJ74 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers (Fiat) 5050 Lift
    Posted: 16 Jul 2021 at 4:46pm
I have an Allis Chalmers (Fiat) 5050 with lift problems.  The hydraulic pump appears to work fine, the control valve has been disassembled & cleaned with new orings. I can "pump" ( lift and lower lift arms) and they will stay up, but slowly come down, but I can NOT get the "lift" lever to function.  Any help gratefully accepted, my current frustration level very high.
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 3:50pm
Have you put a psi gauge on the line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CurtisJ74 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 7:31pm
Short answer is no.  A Allis Chalmes mechanic told me as long as there is some fluid flow, that shold be enough to lift the arms .  And I know there is fluid to the control valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2021 at 8:59pm
This page was generated in 0.191 seconds.
