Allis chalmers diesels vs the rest..
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 3:37pm
Nebraska tests do not equal the real world.  We have a Ford 5640(rated at  68hp), MF 265 (rated 62) and AC 180D (rated 64).  The 180 uses way, way, way, more fuel doing the same jobs as the other two.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 3:44pm
Depends on the job and the weight of the tractor. All weights and load the same the 301 is hard to beat for it's day.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 3:48pm
My FIL, who was a big massey fan and even bigger deere fan, borrowed Dad's XT and was sold completely on the fuel usage and power of the XT and he insisted Dad sell it to him. Dad did and my FIL just loved that tractor. I'll take a good XT up against an 1100 Massey every time.
Wink
I am a Russian Bot
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 4:42pm
Well I haven't run the 301 diesel but I can tell you the d17 226 gas with just pie weights will way out work any ford or ih of the same hp rating. It will drink the gas doing it but that d17 is the hardest working tractor for its size I have ever seen. I suspect the diesel in the newer tractors are the same.
As much as I hate the gas bill for my d17 I am rebuilding the motor because it just works too hard not to.
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 5:59pm
Dy reading this the 301 has been called a fuel hogger but I always heard they were stingy on fuel but what is true
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:05pm
Tractor data ac 185
Nebraska Tractor Test 1044:
Test Date:     May 26 - June 3, 1970
Type:     Diesel 8-speed 2WD
PTO power (rated engine speed):     74.87 hp [55.8 kW]
PTO fuel use (engine speed):     5.3 gal/hour [20.1 l/hour]
PTO power (rated PTO speed):     70.72 hp [52.7 kW]
PTO fuel use (PTO speed):     4.9 gal/hour [18.5 l/hour]
Drawbar power (max):     63.82 hp [47.6 kW]
Drawbar fuel use (max):     5.3 gal/hour [20.1 l/hour]
Drawbar pull (max):     7,568 lbs [3432 kg]
Max pull gear:     1-Hi
Test report:     PDF file
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2016 at 6:55pm
Just my opinion here , and have ran many 301 diesels stock and turned up , turboed  and not , none were fuel hogs at all , and ive, plowed, disced, brushogged, cut , raked and baled hay with 180,s , 190,s 190 XT,S , A 7000, and all were not at all fuel hogs, put 10 gallons in a 180 tank you can cut hay till 1, rake some other field till 3 , bale it and still have some left , maybe the other guys had a leak ? Just kidding !
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 12:35am
Tractor data says 5.3 an hour for a 185... I couldn't put that much through my XT... I didn't run it wide open but in the 1900-2000 rpm range plowing and burned about 3 gallons an hour, doing nearly the same amount as the neighbor who said his 966 was burning 7 gallons an hour.... When we were plowing or discing, it was about 6 cans a day....For each of the XT's... now the 190 gas, less hp., would use about 8 cans  a day... when working hard. and figure about 10 hrs...
 Want to talk about fuel hogs, Uncle had a 450 IH gas and he was out plowing with it and found out when he went out in the morning after chores, you fueled it up before leaving... come in at dinner, fuel it up, and plow till chore time and then if he did any more tilling after chores, he had to fuel up before going back out, or he would be walking home. LOL  Traded that for a D17 gas and was much happier... then bought an 1800 c series Oliver diesel, much more fuel efficient... Traded his D17 for a 170 Allis with cab and loader... and later traded the 1800 for a White 105. He loved the last two tractors. 105 had air conditioning in it. an the 170 had heat in it for winter.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 1:47am
JC that is why I post the tractor data information it looked like a lot of fuel to me but I have only seen a 180 run a baler for a day or two so I had nothing to base it on as the 180 didn't even seem to know that square baler was behind it.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 4:02am
the 180 only uses .4 more gals an hour then the MF. completely different tractors. id check your air filter. Nebraska tests use actual measurable data. real world has to many variables like engine wear, fuel quality etc....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 7:30am
190 XTDiesel 301 turbo was Nebraska test rated at 93.64 HP and only 5.7 Gallons per hr. That, in a way, does make a 185 look kinda bad on fuel useage.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 7:38am
Originally posted by nick121 nick121 wrote:
Yeah, In the 7040  usually start in 3 or 4 pulling wagons  And shift it like a semi, dont even use the clutch sometimes.. no grinding if you do it right.
It's the damage you do while trying to figure out how to do it right that's the problem
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2016 at 9:03am
Glad to know that the scientific tested data is not accurate but we have the super calculated measurement of "way,way,way"!  LOL
My 190 XT is super easy on fuel.  7020, uses more.
Life is simpler when you plow around the stump.
