Allis Chalmers B project
PeterVD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B project
    Posted: 13 hours 60 minutes ago at 5:04am
I'm Peter, 54 years old and located in Belgium.
I started a rebuild project together with my 18 year old son, an Allis Chalmers B
It runs and drives, but not as it should, so we got a little bit of work in the future
It's already converted to 12 Volt
When I find out how I will post some pictures on the forum
I don't know if this works:
Edited by PeterVD - 13 hours 23 minutes ago at 5:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 60 minutes ago at 8:04am
thats a good looking little tractor.. You have the optional 5  bolt rear wheels / hubs... Most of the Bs had a 2 inch spline shaft that the hub was mounted to..
Good luck.. This is a great place to ask questions..
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 46 minutes ago at 8:18am
Interesting rear wheels,has the center nut like the older B's but the centers are different from anything I have ever seen.Maybe something offered in Europe and not in the USA?Very neat tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 37 minutes ago at 8:27am
your right Gary.. I had to blow up the photo to see the nut.... I THINK there were 3 versions of the axle... one had the center nut, one had the 5 bolt flange, and a third was an ADAPTOR hub with 5 bolts that slid onto the original taper spline shaft... That is apparently what he has..
normally the 5 bolt flange came with the straight adjustable front axle as compared to the wishbone axle.. hard to tell in this movie..
Edited by steve(ill) - 10 hours 33 minutes ago at 8:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 1 minutes ago at 9:03am
Can I just ask how I can post pictures here, I don't find a program to upload them
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 38 minutes ago at 9:26am
at the bottom of this post, on the left, there is a POST REPLY box.. Click on that and it will bring up another page... Click on the GREEN TREE icon in the heading of that page.. At the lower left you can CHOOSE your PHOTO from your computer file  or desktop.....
Files need to be in the 800 x 600 pizel size and will be 100- 200 KB... Most cameras are 5000 x 4000 pixels  and 5 MB in size and this SITE will NOT RESIZE for you.. Do that in PAINT or similar before you upload..
Edited by steve(ill) - 9 hours 36 minutes ago at 9:28am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 32 minutes ago at 9:32am
Steve, you have your photo uploads response in a file to copy and paste? It'll keep a broken record
No disrespect to OP or you. Wish there was an easier way
Edited by plummerscarin - 9 hours 32 minutes ago at 9:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 50 minutes ago at 10:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 37 minutes ago at 1:27pm
Peter, sometimes you can get a third party site to post your photos, but the easy way is to have it on your computer or phone and just use the GREEN TREE icon as i posted above..
Some guys post LINKS when they have an album, but a single photo or two is easy with the GREEN TREE.
here is a snapshot of your You Tube video...
Edited by steve(ill) - 5 hours 35 minutes ago at 1:29pm
