Allis Chalmers B Gas Tank Valve |
cfciii03 ![]() Bronze Level ![]() Joined: 20 May 2021 Location: 43560 Points: 29 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jan 2022 at 7:48am |
Rebuilding 1955 Allis Chalmers B and don't want to use a sediment bowl. Any suggestions/pictures for an alternate 3/8 NPT valve ?
Thanks.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88331 |
I rebuilt a CASE 530 12 years ago. Tank was rusty inside and i wanted to clean out over time.. I put a pipe sticking down 6 inches with a cap on the bottom. 3 inches up i put a TEE pointed toward the carb with a 3/8 brass ball valve in the line. Put a barb fitting after that with good inline filter, then hose to carb... We would pull the cap off the stand tube and drain out any CRUD every 8 hours, and changed the filter every couple months.. DId that for a few months, then OK since then.
Check the rating on the brass valve, but most are good for water / oil / gas (propane) application... worked for us. Edited by steve(ill) - 12 Jan 2022 at 8:42am |
