Allis C Rear Axle Lube
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Allis C Rear Axle Lube
    Posted: 06 Aug 2017 at 12:42pm
In regards to the long axle shaft that runs through the top of the axle housing from the rear end to the top of the bull gear , how do the bearings on each end of the shaft get any lubrication?
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2017 at 1:56pm
The only lube that bearing gets is from the excess from the small gear and what might be slung off the bull gear. Leon
This page was generated in 0.053 seconds.
