Allis B with melted lead in the oil pan.
 Post Reply Post Reply Page  <123
Hillmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hillmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 11:14am
The governor isn't the problem, it acts the same wit the governor bypassed completely.
But none of it matters any more. When I took off the carburator I saw a water leak behind it. I scrubbed the grease of the block and found two 10 inch long cracks. So at this point I am done with this engine. I need to find another engine or another tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 12:41pm
OUCH... that Sucks... good luck on the NEW PROJECT..
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 1:01pm
Make lemonade out of lemons, buy a little bigger one to use now, put the B in the shop and swap engines over the winter,then you have a bigger work tractor and the B for a chore tractor,you can NEVER have too many tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hillmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 1:08pm
That is my plan.
I am looking to buy a ed 45 with a wide front. I really liked the two clutch set up they had and it will power my baler easier than the b. But I have a lot of attachments for the b and most of my trails are too narrow for a wd , so I want to get the b, or a b running again.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 1:19pm
Split the difference and get a CA, then you have both clutches, adjustable wheels,a 4 speed transmission, I have a CA and love it, I did see a few CAs on craigslist up in your neck of the woods.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 1:30pm
Matter of fact there's a CA over by Ogema Wisconsin? $2,300 on craigslist. There's only one picture of it but it doesn't look bad from what you can see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hillmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 9:04pm
I didn't know ca's had a hand clutch. Is it just like the wd where it disengages one wheel but keeps the pto and hydraulics running?
I bought a running b this afternoon for $400 but the owner wants to keep the wheels and tires, and the manifold. I should be able to swap parts and get a running tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2022 at 9:09pm
running B for $400. is a good buy...... B is narrower than the C or CA... good for your trails.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2022 at 6:56am
Yes sir the hand clutch works like a WD series. A CA is little bit bigger tractor than a B , about a foot longer,800 lbs heavier dry weight,wider and a few more horsepower. I put 12.4 x24 tires on mine, it has a Cross 3 point conversion on it, sometime in it life someone put a CR engine in it (power unit) I just put a new governor in it and that gave it a bunch of snap, I also bought a wide front end for it from a member on this site that's going on it this winter. I use it with a 5 foot bush hog,50 gallon boom sprayer,seeder. I have a 2020D with a loader that I do any kind of loader or dirt work with but my CA does a lot of work as well.
