Allis b "soft seizes" but not overheating? |
Pengineer
Topic: Allis b "soft seizes" but not overheating?Posted: 27 Oct 2026 at 10:14pm |
Brand new member, my 1st tractor, a 40s era model b with front end loader. I finally got the seized engine broken loose and running well but periodically it tries to seize up while running. It stalls the engine and sometimes is hard to turn over but after a few minutes starts and runs well again. I'm reading good oil pressure and cool engine temp. I've had the head off numerous times and tried to blow out all the oil and coolant passages.. Any ideas for me??
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9264 |
Posted: 27 Oct 2026 at 10:45pm |
I would bet you have corrosion on outsides of piston that takes up wall clearance. You said it "was" stuck. Unstuck and clean are two different things. Pull the head again and knock the pistons out to ensure all is well. Bet you find your answer.
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 512 |
Posted: 28 Oct 2026 at 12:16am |
My B would do that, i cleaned the cooling system many times I found out that the thermostat was broken and blocking the passage.
'41 Allis B
'49 Farmall Cub |
Phil48ACWC
Posted: 28 Oct 2026 at 5:38am |
Remove the thermostat, put in water in a pot on your kitchen stove. Turn the burner on high and use a meat thermometer to note at what water temperature the thermostat starts to open. It should start to open at the rated temperature of the thermostat. If it opens substantially late, its junk. A good radiator and cooling system flush would also be a good idea.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5489 |
Posted: 28 Oct 2026 at 6:55am |
These engines commonly build up rust and scale around the rearmost sleeves and this blocks coolant flow. After years of no or poor quality anti freeze, sometime the only way to really clean this out is to remove ALL four sleeves.
Pengineer
Posted: 28 Oct 2026 at 8:50am |
Wow. Thank you everybody, all this is most helpful. I guess I'm tearing into her again, hopefully for the last time! By the way, I've ordered a new thermostat but in the meantime I've been running with the old thermostat removed entirely and I'm surprised I can't see much of any movement of antifreeze in the neck of the radiator. But both upper and lower hoses get warm. The gage never gets over 120 degrees... so it makes sense the coolant is not flowing freely. Bill
Joined: 11 Sep 2009 Location: illinois Points: 93502 |
Posted: 28 Oct 2026 at 9:10am |
might be a good idea to look at the impeller on the water pump ??? NExt time you have the head off, stick an air nozzle / 1/4 inch rod, down the water ports around the cylinder sleeves and poke around, blow to stir things up... then flush.
Posted: 28 Oct 2026 at 9:35am |
I might try something like this: remove the carburetor or manifold to gain clear access to the block's coolant drain hole, which I think is 1/4" pipe thread (an actual 1/2" diameter hole). Remove the petcock from the block to get a large of hole as possible. Fabricate a 1/4" copper tube or a 1/4" steel brake line say about 6 inches long to fit into the hole in the side of the block. Bend the tube to go around the corner to try and aim towards the front and back of the block. Connect this tube to a pressure washer and start in, flooding the lower block area for a short time and let it empty itself. I don't think faucet water pressure would be adequate enough to bust up the rust, but maybe. When the color of the water becomes pretty clear, call it good.
Edited by DrAllis - 28 Oct 2026 at 9:38am |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 56158 |
Posted: 28 Oct 2026 at 3:42pm |
Get a IR thermometer, and take some temps, around the block, this will lead you to the hot spots...
Posted: 28 Oct 2026 at 5:06pm |
to expand on Dr idea... i think there are 3 freeze plugs on the side of the bock behind the oil filter and mag.... you might knock one out and take a look !!!
Pengineer
Posted: 28 Oct 2026 at 9:14pm |
Thank you all for all these great ideas! This is such a great forum. Bill
john2189
Posted: 29 Oct 2026 at 6:01am |
Isn’t that an oil galley behind those 3 big plugs? Not water ? |
'41 Allis B
'49 Farmall Cub |
PaulB
Posted: 29 Oct 2026 at 6:51am |
Anyone would be wasting their time removing the soft plugs shown, they any give acess to pushrods and lifter tops.
Edited by PaulB - 29 Oct 2026 at 6:51am |
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1328 |
Posted: 29 Oct 2026 at 8:36am |
As far as harm goes? The neighbors had a B with a woods mower that would do the same thing. As the dad got older, when the tractor siezed, it was time for lunch. After lunch he finished the rest. It got ran like that for 10-12 years like that before something finally let loose.
