Allis B running weird
Ttague39B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Topic: Allis B running weird
    Posted: 26 Aug 2025 at 12:06pm
Hi, I have a 1939 allis chalmers b that is idling fine, but as I start driving it it wants choke to run. The ajustment screw is nit changing anything, (im running it on a zenith carb full metal needle) and the other day when I went to start it it kept stalling after moving 10 feet, but would restart fine. A few days later it idled for about 15 minutes great, then went to move it and stalled right out. Any ideas or thoughts? Thank you.
Straanger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Straanger Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 4:51pm
How old is the fuel? When was the last time you cleaned the carburetor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ttague39B Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 4:55pm
Fuels maybe 2 months old, non ethanol, its only been a year, maybe two.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 5:39pm
main jet plugged......... choke on means lack of fuel..
Orange B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange B Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 5:39pm
hi, sounds like there is a blockage in the fuel line due to dirt  either floating around in the tank , fuel line , or the screen in the fuel bowl. I have had that happen in the past on my 48 b. I would take the fuel line off at the carb see if the fuel flows freely ,  if not work towards the tank a section at a time till you get a free flowing line .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:09am
39B,
 As others have suggested check for good fuel flow. I just had our freshened CA do something similar. Fuel was flowing good. It was the condenser in our CA! Yep sounds strange but it had no power ran only at idle and very rough! Might be worth a thought as you do trouble shooting on your B.
Looking forward to your updates.
Chris and Cheryl
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 12 minutes ago at 7:29pm
I have had so many issues that turned out to be just old fuel gumming up float valve or a carb passage.  Had a bad magneto long ago on my B but it only acted up when it got good and hot.  Luckily a guy up the road rebuilt magnetos at the time and got me back up and running.
