Allis 7060 help
twinsonfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7060 help
    Posted: 14 Oct 2019 at 1:24pm
What is the trick to getting the oil pan off the engine?  When I drop the pan, I can't remove it because there is something blocking it from sliding down and rearward?  Looks to be the timing gear?  I can't drop it straight down because the tie rod bar is still on the tractor?  Does that tie rod bar need to come off in order to drop the pan?
Edited by twinsonfarm - 14 Oct 2019 at 1:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 1:43pm
Tie rod has to be dropped at least on one side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinsonfarm Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 1:46pm
Thanks.  Any tips on removing the tie rod?  I can't get the tie rod to budge?  I have tried the pickle fork? sledge hammer,  next is heat but I'll probably end up damaging the boot.  Uhgg....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2019 at 3:41pm
8 ft long prybar. One big person pulling downwards on prybar forcing tie rod down. Someone else strikes the very rear portion of the eye that is holding the tie rod. I use a 4 lb hammer. Leave nut on but loosened to catch things when it breaks free. NO HEAT.
