Allis 7020 |
leader58
Joined: 15 Oct 2013 Location: Wilmington,IL Points: 103 |
Topic: Allis 7020Posted: 04 Mar 2017 at 11:32am |
Can the front harmonic balancer seal be changed from the outside on the 7020?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8742 |
Posted: 04 Mar 2017 at 12:02pm |
tricky but yes.Usually a small self tapping screw (or three) gives ability to pull with prybar.Crank in way makes it harder to clean bore and drive new seal but can all be done with some ingenuity and patience.
MACK
Posted: 04 Mar 2017 at 9:54pm |
A little heat around outer dia. Of seal will make it pull easier. The seal has locate on it and 300 degrees will loosen the locate. MACK
ACjack
Joined: 13 Sep 2014 Location: Peoria, Arizona Points: 277 |
Posted: 05 Mar 2017 at 9:22am |
If there's loctite on the outer edge of the seal then that isn't the factory seal in there. The factory seal had a "rubberized" red coating on its outer OD to seal against oil leaking past the seal OD and the front cover.
MACK
Posted: 06 Mar 2017 at 7:45am |
The rubberized coating is a form of loctite
. MACK
Sam T-Ga
Joined: 13 Sep 2009 Location: Monticello, Ga. Points: 392 |
Posted: 06 Mar 2017 at 6:22pm |
I think you have to pull timing cover on 301 engine, seal is pressed in from backside of cover. There is a lip on cover that protects seal.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2438 |
Posted: 06 Mar 2017 at 7:46pm |
Sorry Sam,but there is no need to pull the cover. Seal is pressed in from the front.
