Allis 7020 Cold Start Issue/Engine Health?
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7020 Cold Start Issue/Engine Health?
    Posted: Yesterday at 8:02am
I could use some advice on my 7020.  My issue is that it refuses to start cold (tested in 50F shop).  Background is that this tractor has an engine transplanted out of M2 combine that I moved the intercooler parts over from the 7020 engine.
·         The injection pump and injectors were rebuilt within the last 90 days.
·         In swapping over the hardware from the original engine, I did pull the cam to replace the front plate…and therefore I reset the tappets.
·         The starter and batteries seem to spin the engine fast enough.
·         In trying to start it cold, I tried it at ¼ throttle and full throttle.  Neither yielded success.
·         Using the glow plug for 60 seconds as a starting aid does not help.   The intake housing does get warm during its’ use, so I think the glow plug is working.
·         If I plug it in and allow the block to get to 80F, it will start.
·         I measured compression with all injectors out using cranking speed and a cold engine. The cylinders range 200 to 210 psi across the 6 cylinders.
o   This evenness leads me to believe I don’t have one or two dead cylinders.
·         I measured compression after letting the tractor get up to a running temperature of 140F.  I then pulled #6 injector, installed compression tester and then restarted it running at idle (750-800 rpm).  This yielded a compression of 350 psi.
o   This above test matches what I found in a 185 Service Manual…it states under similar circumstances, a healthy psi is 500.  My 7020 Service Manual offers no criteria for a compression test.   I noted from the parts book that the piston from a 185 to a 7020 is a different part number so I don’t know if I can use the 185 spec.
·         When running, the engine has near zero blow by out of the valve cover.   This makes me believe the engine isn’t shot.  Also, I can run it down the road in high gear and it seems to have plenty of power.  I wish I had access to a dyno to measure actual horsepower.
What are people’s thoughts on what my issue is?   Has anyone ran a compression test on a healthy 649/301 turbocharged engine?
Edited by nowaktj - Yesterday at 10:38am
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:28am
Who put injection pump in. Maybe not timed correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:34am
Forgot to add detail about timing.   I have double checked and the lines match up perfectly for 18 degrees BTDC.  The dampener mark could be off, so I moved the pump gear back 1 tooth and forward 1 tooth and it did not run as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:46pm
So, how did it start cold when in a 50 degree F shop before you had injectors and injection pump gone thru ????              Set your pump timing at 16 degrees BTDC and leave it there.     Cranking compression with a known good compression tester should be over 300 PSI with all injectors removed. Running on one cylinder at 700 RPM should yield you 400 psi or a little better.  So, you either have a real problem or you have a compression tester that isn't giving you correct numbers.       What brand starter does it have?? A LUCAS ?? they are known for slow cranking speed, regardless of what you think of the cranking speed. I assume this engine has the DM-4 style injection pump?? and that would have 15 to 1 compression pistons. LEAVE THROTTLE AT A DEAD IDLE TO START.
Edited by DrAllis - Yesterday at 1:54pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:30pm
200 psi is not enough to start a cold diesel engine. I always do compression tests with starter, not per Ac procedure of it running on the other 5 cylinders. You problem starting is at cranking speed, so that is the speed you need to check it as you did, and it proved to be a problem. Faster cranking speed will definitely raise the cranking compression pressure. I don't feel you have an engine problem as much as you have a slow cranking problem. Looks like a great application for an ether start and a gear reduction starter lol!
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 31 minutes ago at 5:11am
One of my 200's had similar starting issues
We up-graded it to a gear reduction starter, put in new batteries, and made new 2/0 battery cables for it. Starts pretty darn good now.
Darrel
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 46 minutes ago at 9:56am
Question: Does it 'smoke' when turning over ?  Also Docs question about BEFORE the repair starting status is necessary to diagnosis. Ed's question of compression pressure at CRANKING SPEED with starter. Also when it does start it runs good ?
If it emits grey smoke and will not start either the timing is issue or it has low compression. Usually the blacker the smoke the more likely a timing issue.
IF it does not smoke at cranking speed - the injectors were set too high for a worn pump head. my 2 cents
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 19 minutes ago at 10:23am
does smoke start coming out of the stack as soon as you start cranking? If no smoke, there's no fuel,  no fuel means its leaking down someplace
This page was generated in 0.152 seconds.
