All Crop 60A |
Page 12> |
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 589 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jun 2024 at 11:27pm |
Well I got one on an auction today and took my 45D to pull it to its new home.
It has a new reel and a new pick up chain/belt but the engine is stuck (it won’t crank over) and it has really old gas in the gas tank. Any advice would be appreciated!!! I’d like to get everything working to “play” with it if it’s possible… So here comes another project!!! ![]() Edited: I changed the title to 60A Edited by 55allis - 16 Jun 2024 at 3:45pm |
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 2871 |
That's an interesting combine. It has a pickup head with a reel.
I see it has duals on it too. That's a nice addition.
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Elk River,MN Points: 1925 |
I have the PTO shaft and shield if you decide to remove the engine.
http://lonsallischalmers.com
Is the pto shaft the same as a roto baler?
I have 4 parts roto balers with the ptos… It also has a sickle bar under it.. I’m slightly confused about what kind of head it is, it has a tag but I didn’t get a picture. Got it from the Royal Bierbaum auction yesterday so there might be more pictures on there. https://www.equipmentfacts.com/listings/farm-equipment/auction-results/232812773/1951-allis-chalmers-60 Edited by 55allis - 13 Jun 2024 at 9:27am |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50826 |
If not a perfect swap, its mighty close!
Well than it would a cheep swap if I can’t convince the engine to come loose!
![]() I sure would like to get it running if it’s possible though. |
Darwin W. Kurtz ![]() Orange Level ![]() Joined: 06 Apr 2010 Location: Westphalia, KS Points: 4807 |
nice machine, unusual set up, hardly ever see one with the engine.....wouldn't that be the same engine as some of the popular tractors of that time, seems some of those have been swapped in the past
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 6790 |
Same engine as a ‘B’ or possible ‘C’?
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3682 |
Do you have the manual for that unit? And what is the serial number?
I only have a online parts catalog. I don’t even know where the serial number is on the machine… ![]() I know it’s missing at least a 4 belts so I’m going to need to cross them. |
I have an original AC manual that covers operating instructions, special attachments, and repair parts book. Says it covers serial 93799 and up. I've had it for years and I'm never going to use it so if you send me a private message through the Forum with your mailing address, I'd be happy to send it to you. It's in good shape and complete for it's age.
Don Jr NY ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Waterloo NY Points: 335 |
The serial number is stamped into the left hand side of the machine right under the threshing cylinder shaft. Left/Right is always as you are standing behind the machine looking forward. Hope this helps. Don Jr.
The serial number is I think A54731.
This one is for 93799 and up, but it would probably have all the info you would need.
That would be a 60 A series machine, since serial number starts with A, I guess the A's were somewhat updated, don't reall know the difference in the actual machines, but they are different and I don't think there were nearly many 60A's built
Here’s what I found online…
Well the engine is shot…
I pulled the head and found 1 broken sleeve and 4 out of 4 broke up pistons… ![]() ![]() |
Nah, couple cans of WD40, charge up the battery, and your good to go!!
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 1828 |
At least it's not some oddball manufacturer's engine. You should still be able to get all the parts you need since it's the B/C engine in power unit form.
New sleeve and piston set and a couple of gaskets and you're well on your way!
Well I think I’m going to put the pto on it for now and than eventually get the engine to run (overhaul and clean it up).
Does anyone know of a stock of parts for the 60A? It needs 3 pulleys, elevator door (rusted out), and a elevator chain. That’s what I seen so there’s probably more things that I haven’t notice…. |
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1033 |
Tom yaz will have it all
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8197 |
Which pulleys do you need. We also have a bunch of pulleys
I have some parts for sale.
Well I have good news today, I was cleaning the walkers out and found the 2 pulleys and the rest of a slip clutch all in the coon crap so praise the Lord!!!
Now the one slip clutch with 3 spring is missing 2 out of 3 springs and the single spring one is missing it’s spring. So now I need to repair and replace parts of the elevator chains (salvage what I can) and figure out belt sizes. Also I think the draper needs to be tightened because it won’t turn unless I hold it tight. I also tried to get the engine clutch to move but knew instantly that it’s going to have to be replaced because the springs are falling out so I’m really hoping that it’s the same clutch as the tractor B… ![]() ![]() |
I"m interested in the header. That's an interesting setup. Good luck getting it running
I found another one down in a neighbors creek that possibly could have some parts salvageable… It’s upside down and beat up pretty bad I’d say….
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3224 |
Restore it man!!
I think it’s a tad gone to far… |
Page 12> |
