adding a 3 remote to 7000 series |
acer
Topic: adding a 3 remote to 7000 seriesPosted: 03 Mar 2017 at 8:45am |
Lonn
Posted: 03 Mar 2017 at 8:46am |
Are you asking or telling?
Wink I am a Russian Bot |
acer
Posted: 03 Mar 2017 at 8:49am |
wow i hit the button too soon i guess, has anyone ever added a 3rd remote on a 7060? is it any more involved than adding the lever in the console plus the cable and adding a valve to the stack with hoses and linkage of coarse,or is it a PITA?
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2206 |
Posted: 03 Mar 2017 at 9:36am |
I just added a 3rd remote to our 8050. The worst part for me was installing the lever. First off the pin was froze, then dangling out the cab and working around the seat trying to line up all three levers and spacers was aggravating. I was told to replace all o-rings between valves, which I did. The 3pt valve has a small poppet spring inside. Also, lower your lift arms before loosening valve bolts. Had I remembered that, it wouldn't have made such a mess.
Leon B Mo |
Unit3
Posted: 03 Mar 2017 at 10:06am |
I added a 3rd and 4th in both the 7045 and 7080. I was told that I needed to cut off most of the threads of the cable end inside the cab as because it is just a little to long for the yoke and lever.
Install everything and check to see if I am right BEFORE you make a cut. I has been about 10 years since I have on one. To add a 4th, take a long lever from the front set and make 2-90 degree bends in it. The lower bend brings the lever just under the front cables and the second bend runs the lever upward just behind the third lever. You also have to add a cable holder in the back of the console for the forth cable.
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 792 |
Posted: 03 Mar 2017 at 10:10am |
any one have a photo of the levers in the cab after a 3rd or 4th lever was added?
acer
Posted: 03 Mar 2017 at 12:31pm |
thanks for the info,never thought about a 4th one but while im at it i may consider that
acer
Posted: 07 Mar 2017 at 9:49am |
i have just about rounded up everything i think im going to need for this project except for the tie bolts or thru bolts whatever they are called, are these a hard grade or something? agco is very proud of em @ $28.00 each and im not willing to pay that just yet
Posted: 07 Mar 2017 at 12:09pm |
I'm sure they are probably pretty good stuff, even tho they are only torqued to 12-15 ft lbs. I'd see if Cat doesn't have a regular Gr8 bolt pretty close to correct length and put the heads to the left(nuts to the right) and use Cat flat washers under the heads to shim the length to where you want it.
