AC Simplicity 720 help
Hemifish69 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Hemifish69 Quote  Post ReplyReply Direct Link To This Post Topic: AC Simplicity 720 help
    Posted: 20 Oct 2025 at 5:29pm
Need an ignition switch. Looking for a new compatible one.
Going on this 720 articulated I built last year out of two junkers.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2025 at 6:53pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemifish69 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2025 at 5:37am
Bought today, thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2025 at 9:59pm
Interesting build! Appears to be 4x4?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemifish69 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 4:03pm
Yep, 4x4. Have not successfully timed the drives, but it will move under either axle powered. The custom shifter mechanism just needs adjusted. She's been shelved since I finished her enough to go to the 2024 "gathering of the orange " in pinckneyville Illinois.
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 25 minutes ago at 12:25pm
This is an exact ignition switch replacement.
Stens 430-249.  You can buy from John Deere under part # AM103286 or online from many sources.  Should be +/- $20.00.
Edited by mnoonan-NEWI - 2 hours 23 minutes ago at 12:27pm
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemifish69 Quote  Post ReplyReply Direct Link To This Post Posted: 49 minutes ago at 2:01pm
Thanks!
