AC B whine in PTO pulley
armorton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armorton Quote  Post ReplyReply Direct Link To This Post Topic: AC B whine in PTO pulley
    Posted: 8 hours 52 minutes ago at 4:43pm
Hey folks -
'49 AC B, with PTO running a Wood L59 mower deck.
Just replaced both bearings in the idler wheels and two spindles (left and right, center was replaced a few years ago).
Now there is (or maybe there had been and I wasn't noticing it with ear muffs) a whine in the PTO when running the deck. No whine if I run the PTO with the belt off. Checked UTF - was low some, but filled it up, and no difference in whine. I can't tell if the whine is because of bearings on their way out, or the gear that drives the shaft is going to make noise because of how it's cut. Does a proper running setup make much noise?
Also, watching a Youtube video, I see there's an oil tube that receives oil from the differential splashing it up in the PTO, so I suppose that tube could have dropped out. There is a little play in the shaft in and out.
Edited by armorton - 8 hours 49 minutes ago at 4:46pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 50 minutes ago at 11:45pm
I would try listening to the PTO with a broomstick (or whatever, I usually use a BIG screwdriver just because it's handy). Try it with and without the belt installed, also the mower if you can access it safely.
