AC B stuck in 3rd gear
Wil M (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wil M (NEIA) Quote  Post ReplyReply Direct Link To This Post Topic: AC B stuck in 3rd gear
    Posted: 27 May 2010 at 9:37pm
Calling all B experts, buddy of mine just called and some how he manged to get his B transmission stuck in 3rd gear and can not get it out.  He has the side cover off and can not get the gear to move on the shaft and back into position.  Any suggestions or anyone have this problem in the past and know how he should proceed to get his tractor to shift.
Thanks
Wil
"Yet there are soulless men whose hand and brain tear down what time will never give again." Anderson M Scruggs
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2010 at 10:42am
Just had that with my donor B, sprayed with Liquid Wrench and used a wood dowel and a hammer to move the gear.  A large screw driver might work or a small bar. Tell him to be careful with the cover, it is cast.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
safetydon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote safetydon Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2010 at 7:37pm
Had the same problem with my WD.  Took everything apart, found nothing, still could not move the shif lever.  Light tap on the housing with a rubber mallet and it was free.  That said, there was some very light rust in a few areas and we decided some rust fell into the end of the stick so we cleaned or replace everything.  Once it's open, the replacement parts in there are pretty reasonable for price and easy to get back together.  I had a friend help with my rebuild and it took him about an hour.  This was just the gear shift box, not the whole tranny.  Then we welded up the end of the stick for tighter shifting.  All in we had about 5 hours and under $100 for (new) parts.  My advice, take everything apart, clean it, replace anything that looks worn, it's well worth it.
Good Luck,
Don
This page was generated in 0.083 seconds.
