AC 80 t wear plate position?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: AC 80 t wear plate position?
    Posted: 07 Oct 2021 at 5:54pm
Where exactly do the wear plates fit on the bar does anyone have any drawings of how these go together that are specific and clear or able to describe it? I bought five new wear plates but things seem a little out of position, thanks Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 6:06pm
The wear plate will fit on the bar front edge. When the sickle it moving in and out, while cutting hay, the sickle blade pushes back against them to save wear on the bar itself. They are throw away wear parts. Should be captured by 2 bolts each. Some will be under the hold down clamps, but not all. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 6:33pm
Okay some of the actual sickle was up on top of the wear plates in the entire 90° edge that I suppose they would ride on was pretty much gone. There's a very long looking wear plate up by the cutter head that the sickle is riding on top of? Is it possible that the sickle rides on top of the long wear plate by the sickle head and not on top of the other wear plates but out in front of them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 8:01pm
there’s a long wear plate 13 bolts I think 12 teeth then starts with short wear plate, two bolts, skip a bolt then another. Uses five shorts.
Edited by Mikez - 07 Oct 2021 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 8:08pm
Hope that makes sense. Quick sketch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 8:42pm
Yes and thank you very much for taking the time to draw that because it's telling me that something is not set up right to begin with because my entire sickle bar is or was riding on top of all the wear plates. Edit, now that I'm looking at your picture again it does look like a small portion rides on top of the where plate and the other portion pushes up against the small bent piece. Thanks Matt
Edited by Hunt4Allis - 07 Oct 2021 at 8:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 8:49pm
If that drawing is correct the very back edge of the sickle blade rides on top of the wear plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 11:09pm
what issue are you having.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 12:24am
That is correct, sections on the sickle knife bar over hang to the rear of the bar and ride on top of  the wear plates. The sickle knife bar rides against the front edge wear surface of the wear plate.  And the arch clips are adjusted to hold the knife assy down in that position... They do overhang?? Mikes diagram would be accurate...Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 12:29am
don’t forget the washers under each clip “hold down”. If you forget them and tighten bolts it will pinch the blades
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 4:34am
Does what overhang? I'm just rebuilding it and there are no washers on any of the bolts that I took off under the hold down clips?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 6:36am
Pinch blade? Doesn't the hold down clips contact each knife section to hold it down?
Wish I had a detailed picture of exactly how this should look when correct( with washers and everything)
Thanks Matt
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 7:31am
Are you using original individual guards?  I converted to New Holland style twin guards years ago.  No need for wear plates.  Only guards and hold downs.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 7:45am
Could you post a picture of that configuration? Can't seem to picture it in my mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 7:51am
Yes original guards
Link to upgraded guards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:31am
The original A-C wear plates were of different lengths. Here are diagrams and instructions on adjusting them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:43am
I don't see washers needed in between hold down clips and wear plate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:56am
Operators manuals, Parts books and service manuals go to great lengths explaining things, however they can't understand things for some.
everyone should have all 3 manuals for all the equipment that they are working with.
Edited by PaulB - 08 Oct 2021 at 8:57am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:58am
Great thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 9:01am
I guess I was referring to Mike's comment, hoping he would know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 9:08am
Brian post the next page where it shows #9 the washers. Qty 36 or 38 part number 920310 or old #911430
Edited by Mikez - 08 Oct 2021 at 9:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 2:04pm
Here you go Matt. Page 58
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 2:09pm
And....page 59
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 8:41pm
Brian, the New Holland style guards have a ledge area that supports the back of the knife and keeps the knife level with the cutting area.  Hope this helps explain how they work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:15am
Thanks everyone very much for the info, now I can get this thing back together the right way and get to cutting if we dry out!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:55am
I 2nd the NH style guards and will make the mower cut better too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 7:59am
show us pictures please
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 8:30am
X2
X3
X4
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2021 at 6:50pm
Thanks everybody for your info, got it back together had some difficulties with the breakaway feature on the 80 t tho...
I finally got it apart and was able to get the belt put back on the drive but I had to remove the tension bolt completely. I'm going to get a new bolt because this one looks pretty bad. I know the manual I have says it should break away once it contacts something but not under normal circumstances mowing. Does anyone know how far in the bolt should be tightened to make this happen? Thanks Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2021 at 5:43am
The joint that moves to let it break away was rusted solid. I'm thinking if I put the bolt in about halfway to start with and see how it goes? Can't hurt to ask if someone has one of these and just knows off the top of their head how tight they normally run it on an 80t?(
Edited by Hunt4Allis - 11 Oct 2021 at 5:44am
