ac 7050 pd re-assembly part 1 & 2 videos
cob_crusher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cob_crusher Quote  Post ReplyReply Direct Link To This Post Topic: ac 7050 pd re-assembly part 1 & 2 videos
    Posted: 25 Jan 2019 at 8:05pm
ac 200 7080 653 da d90.06 6265 f400 ol 77 1650 jd 4230. the reward of suffering is experience. ignorance is bliss. no muff too tuff. i am only responsible for everything. free whiskey naked women.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2019 at 11:05pm
I watched all of the first video where he splits the tractor apart. A perfect example of how-not-to work on an AC tractor.  He didn't drive it before he split the tractor to verify/diagnose the complaint...BAD IDEA. Left fuel tank doesn't have to come off.  Not using long dowel bolts to support the rear of the engine is another example of how not to do it. Flywheel bolts were damaged from a previous use of an impact wrench on them. No flywheel oil shield was used. He spent a lot of time with the hood, muffler, air cleaner stack. None of that needs to be touched. Just remove 2 bolts at the rear of the top hood and prop up the hood with a 2 x 4 stick.
Edited by DrAllis - 25 Jan 2019 at 11:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote cob_crusher Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 1:13am
ok. why dont you make some vids so we can get the short cuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 6:47am
Maybe someday (when I have the time) I'll just do that.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 8:22am
I watched 1/2 of second but got bored. Didn't use sealer on seal ware sleeve or flywheel bolts. No dowel bolt to line flywheel, just wallered it around on new seal with no lube on it. All I could stand to watch.      MACK
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 8:42am
This gives a first timer a look at what one will encounter - with the critiques above can be a useful tool.  Also, if one has a leak in the front or rear seal we always check end play. While the 7000/8000 series has no clutch to apply forward thrust, we still had 2 units that had excessing end play - one that had shucked the thrust brgs for some unknown reason.
 Dowels dowels dowels - they make it so much easier, quicker and safer not to mention a insurance of not having to do it again.  Also on the early 7000 series the depth of the inner groove of the clutch pistons need to be checked .  There was a tool to do this but a digital mike will work.  It is also a time when a  lot of owners find out there is a 3d oil filter on the 7060 7080's,,,,  :-)    PS on the EARLY -1976 power shift tractor there is a sleeve where the seal rides on the input to the trannys. There is an oring under the sleeve that must be replaced - little things like this one finds out after splitting 3 times for leaks....
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 10:55am
 I couldn't watch it for very long...
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 12:55pm
The first thing I saw (in the first video) was using a die grinder with no eye protection. When someone  does something like that, I have to question their intelligence.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 2:28pm
I cringed at him hitting the wear sleeve with a chisel as hard as he was. That is how I remove them, but don't hit it like I'm trying to break the casting! I quit watching there, for now lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 4:35pm
Glad this is out there , gives a guy general idea of what he,s getting into on a 7000 series, never been in one but always wondered about the torque limiters as they are a weak point in tractors of this age
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 7:18pm
I liked watching at 1.5 speed.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 7:46pm
Who remembers this torque limiter repair?
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2019 at 8:00pm
Ahh yes, I wonder how that one is holding up......?
