AC 6080 PTO
ssefick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ssefick Quote  Post ReplyReply Direct Link To This Post Topic: AC 6080 PTO
    Posted: 16 Feb 2022 at 6:56am
Hello All:
Note: I have not received my manuals yet.
I have 2 questions related to the pto.
1. The pto connect/disconnect pin is on order. Any gotchas about installation?
2. Button stuck on pto clutch lever. Any thoughts? Sprayed pb blaster to see if this s rust related. Did not work.
I will break in to all of this weekend. I hope. Thought I would ask in preparation in case y'all had some thoughts/advice.
Thank to everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2022 at 11:52pm
no help to your questions.
But the way I understand it. If your using tractor for non pto work you leave the handle on right forwards and the lever next to seat to left in floor down which is disconnected.
If you want pto use. If it’s a cold start where tractor has sat for a bit. You start tractor with levers in the above description. Let warm up. Shut tractor off you pull left  lever up out of floor and pull hand clutch on right back. Start tractor and operate pto with right hand lever.
