AC 6070
Sab View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sab Quote  Post ReplyReply Direct Link To This Post Topic: AC 6070
    Posted: 23 May 2025 at 11:18am
I am a new owner of AC 6070
I have trouble to change my HT oil .   The rear is done (near the three point hitch)
Oil is drain in front axle , but i dont find the way and location to fill it again .  I know that the level is determined by the wheel.
Also do I have an another place to drain and fill.
Filter is changed.
I have the MAnual but dont find the place they explained it  (operator and service)
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 1:09pm
The most important check is the TRANSMISSION . It checks and fills via plug on the side of the housing under the platform on the brake pedal side.  Many owners drain both compartments, fill the rear end - and drive for a couple of miles and the whole tranny locks up.  IF you are talking the front outboard planetary the check plug is the fill plug. 1/2 way up.  The center cavity has a 22mm drain plug on the bottom and another one for the fill. You need to do some more looking in the op man for the service areas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 2:10pm
I would get yourself manuals, owner operators, parts, service. You can buy all three from agco publications.com or search  around on other online places.
