ac 210 |
waynelj ![]() Bronze Level ![]() ![]() Joined: Yesterday Location: canada Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 7 hours 52 minutes ago at 7:54am |
my 210 slips out of 1st/5th as soon as the clutch is engaged...can this be fixed easily or is it a major repair, ie do I learn to live with it!
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22012 |
To properly diagnose the problem, you need to remove the center platform and the shift cover to investigate. My gut feeling is that particular gear has been ground into gear so many million times since 1970 that the shift nubbins are all ground off the gear and the shift coupling. I would expect it to pull a load, but jump out on a downhill coast. You might have a broken shift fork. Removing the shift cover to inspect will verify that, but I'm thinking major repair work.
