ac 190 cab
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 8:07pm
I have one of the split door cabs I got from Andrew in Nebraska. It factory AC would go in the panel on the right side. If one was avaliable. I have no use for AC in the summer the Windows fold back and secure opened. I do remove the lower door in the summer just pull the one hinge pin out and hang the door in the tractor shed. It bolted on my tractor in a couple hours. Andrea sent all the filler panels with when I picked it up. It would fit in the bed of a full size pickup but I put it on a snowmobile trailer. Screw a couple blocks into the trailer deck and strapped it down real well. I also strapped around it to secure the doors and windows in the closed position. Drove 75 mph all the way home. Had one flat tire 10 miles from home after driving 1000 miles. Other than the lower door being a pain it's a good cab. A lot nicer than sitting out in a blizzard or rain storm. If your tractor dosent have the platform support brackets you must put them on before adding the cab or you will break the cross supports in the cab floor.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2020 at 11:06pm
My 190 has that stopler on it,--half door leg grabbers,--real PITA but then I don't use the tractor so it don't bother me!
