A-6 air conditioner compressor |
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2486 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Oct 2025 at 4:03pm |
I recently put a clutch coil and bearing on the compressor on my 7060, well,, now the clutch hub decides to self distruct,,
Now being somewhat resourceful,, I thought I'd take the clutch hub off the compressor I replaced on my cadillac,, same compressor,,right, oh, but NO!!,, I don't think there are any 2 of A-6 clutches that are the same,grrrr ![]() ![]() If that isn't a problem,, the belt groove will be in a different place on the drive hub....luckily, I not having to change that... Edited by Michael V (NM) - 02 Oct 2025 at 4:06pm |
Well, I ordered a clutch hub off the interweb, looks like it's the right one,, so,, the Ole A-6 gonna live a little bit longer. For nor more than I use tractors any more,, be a long while before I change to a sanden, although, that is preferred, just to many dollars for the few hours a year I put on the tractor nowdays
I only gots about $130 in the A-6 as of now,(clutch coil,bearing,hub) not counting occanasional can of freon or 3 Edited by Michael V (NM) - 08 Oct 2025 at 9:02pm |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8726 |
Good morning, Michael. Any time you can fix something for 130 bucks in this day and age, call it a win! Down there where it gets hot, you need to stay cool! Have a good one! Darrel
Yra, Darrel,, and my thoughts are,, if it's got it,, it needs to work,, an with my hay fever/allergies,,I kinda need it to work, especially mowing weeds, or cutting hay
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8651 |
I spend whatever it takes to have working AC. 2 Gleaners 3 8000's. That's just me.
