a couple photos |
Russ SCPA
Joined: 12 Sep 2009 Location: Southern Pa Points: 256 |
Topic: a couple photosPosted: 30 May 2010 at 9:22pm |
Basically very even match of power and traction. Running Michelin XM108's 650RX38 singles, no fluid, 12 psi, last dyno test showed right around 165 pto hp, 4th gear, not quite enough to get 5th on chiseled ground, we are fighting some hills. Disc wheels are "clear up", so the depth of cut is possobly more than necessary but this is a "new to us" farm and was a mess. Since we went to the low pressure, no fluid radial I feel the traction is better, and no "power hop".
I would say the 7060 is a minimum for this disc in my conditions.
24" blades, and they are nearly new.
StewartMD
Joined: 10 Dec 2009 Location: Emmitsburg, MD Points: 314 |
Posted: 30 May 2010 at 8:47pm |
Russ, With your 7060 and 2600 disc are you limited by hp or traction? Also are you running duals, radials, etc? We would like to get a 2600 disc someday but want to make sure we can put it.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
Rfdeere
Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
Posted: 30 May 2010 at 4:15pm |
Ahh, Don that 45 will walk the dog with that disk. (As long as you don't put her in the ground) LoL !
http://www.rumelyallis.com |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 30 May 2010 at 8:36am |
Hey Russ, How do you see the row markers in no-till?
I don't think my WD45 will pull that disc! lol
Don
Russ SCPA
Posted: 30 May 2010 at 8:17am |
Couple photos I hope.
7020 on a White 6100 and a 7060 on an AC 2600
this is a before shot
21 feet of 2600 disc takes everything the 7060 has.
