8050 Vibration Damper
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Vibration Damper
    Posted: 17 hours 60 minutes ago at 8:51pm
I noticed a slight wobble of the crankshaft pulley while the engine was running. Looking closer I noticed the neoprene on the damper was cracked and not spaced evenly around the circumference. Didn't look like there was any recent movement, but don't think this is proper. I tried doing a search for this subject and came up empty. I seem to remember this topic discussed on here before and believe there was a place out in the NW USA that rebuilds dampers. Would appreciate thoughts and comments on this.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 44 minutes ago at 6:07am
Jim, it has been discussed. Seems like not that long ago. If memory serves a dampener from a Detroit diesel of some sort might work?
Edited by IBWD MIke - 8 hours 40 minutes ago at 6:11am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 11 minutes ago at 7:40am
Mike's link discusses the fluid dampeners used on the higher horsepower engines. I'm not sure if the guy in Oregon?? is still rebuilding the rubber dampeners. Dale manufacturing, I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 55 minutes ago at 7:56am
Right Jim is referring to the rubber in the crank pulley
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 60 minutes ago at 9:51am
Dr Allis had one rebuilt not so long ago.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 1 minutes ago at 10:50am
Yes, and I had it done by Dale Mfg in Salem, Oregon. Address is 3425 Fairhaven Ave NE zip 97301.  Email: langsatherdavid@gmail.com     It is my understanding that he has officially retired now, but check that out for yourself.  A & I products has new ones with p/n A-74037126.
ecosse23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ecosse23 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 11 minutes ago at 1:40pm
Purely out of curiosity I had a google search, and turned up a firm in California -
http://damperdoctor.com/ - which lists custom rebuilding of harmonic balancers, including for heavy equipment.  May be worth asking them, just in case they can help?
