8050 Hydraulic Remotes are Slow
jstewart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jstewart Quote  Post ReplyReply Direct Link To This Post Topic: 8050 Hydraulic Remotes are Slow
    Posted: 11 Apr 2012 at 9:43am
Tried to turn the t-handle on the remote valve, didn't seem to make a difference. Are they threaded; or spring loaded and I need to push in on them as I turn to make them catch a notch or something. As I was standing at the rear of the tractor I was turning them counter-clockwise, and I turned them quite a bit, but it didn't seem to make a difference.
Thanks for any help.
Jared
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 11:38am
The roll pin on the flow control spool should have a long side and a short side.....long side straight down is fast......long side straight up is slow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jstewart Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 12:54pm
Thanks a million DrAllis, I'll give that a try tonight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 7:20pm
Now that I'm home and relaxed, I gave you bad advice.....Long side down and up is for 7000 series........I think the 8000's were 3 o'clock and 9 o'clock.....only one-half turn from fast to slow.......you can turn them 100 times and it does nothing, it's where you set them at.......put one and 3 o'clock and the other at 9 o'clock and you'll figure it out. THIS INFO IS IN YOUR OWNERS MANUAL with pictures.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2012 at 10:53pm
Look under the seat, towards the back of the cab. Could possibly be a flow control for one of the remotes there with a decal showing fast and slow. Orientation of the rest of the remotes is the same. Darrel
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 4:15am
The handle on my 7060 was on backwards!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jstewart Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2012 at 6:25am
Thanks for the replies guys. I didn't take much time to mess with them last night, I put both of them down and one seemed faster than the other so I switched my raise/lower to that remote. I can attest to turning them and nothing happening, I about wore out my fingers the other day turning them to no avail. There is a picture under the seat with a fast/slow, I assumed (know what that will do) it was indicating the direction to turn the t-handle, not indicating a position. I'll get back to it again tonight if it doesn't start raining early.
Thanks again,
Jared
