8030 pd hydraulic issue
Oldred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Topic: 8030 pd hydraulic issue
    Posted: 12 Apr 2019 at 12:10am
Fired up the loader tractor to put out a couple bales and tractor had developed a loud squeal as well as transmission low oil lite on. Shutdown checked all oils which were good, fired up and no squeal. Low oil lite still on hit throttle a bit still lite on. Then put in gear no movement no hydraulics no steering. Shutdown. I am gonna start with the pump drive, then hydraulic pump. Is there a coupler that can strip the splines out on these units ? Never had one apart before. Thx for any ideas/info/experience. Tractor is an 83 8030 FWA PD.
Mark
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 6:33am
Hub broke out of torque liminator.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 7:12pm
Can that be changed from the front of tranny behind the pumps or is that a split job ? Never had anything to do with the torque limiter.
Edited by Oldred - 12 Apr 2019 at 7:13pm
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 7:24pm
Split job.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2019 at 8:57pm
Split at back of motor. Be a perfect time to rebuild powerdirector clutch.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 12:30pm
Put a new rear main seal in it while you’re at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 3:15pm
Some engineer at the time thought wow such good idea sure wasn't! But as time goes on everything wears out
Edited by DougG - 13 Apr 2019 at 3:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldred Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2019 at 7:58pm
Thx for the replys fella's.
Gonna get it all washed up, remove loader and start the disassembly next week.
Later Mark
