8010 under powered
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 6:34pm
Originally posted by injpumpEd injpumpEd wrote:
exSW is working on a 7010, virtually the same. low boost and black smoke tells me either the turbo is junk, or as simple as a boost leak, missing plug, or blown intake gasket.
I'm going to try the cheap stuff first.
Off to the pressure washer in the AM.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 3:10pm
Well,she's clean. But there's nothing obvious. The crossover from the intake manifold to the turbo does appear to be RTVed up at the manifold but that doesn't mean it leaks. Is there a way to pinpoint boost leaks?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2019 at 5:19pm
Like maybe take a proper sized PVC cap tap an air chuck in it. Then plug it into the fresh air inlet for the turbo , pressurize the system and listen.
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 5:26am
So many worry about the 8010 and it’s power. It’s a small block in a big chassis. I compare it to a 350 in a 2 ton truck. You can get to elevator but your not going win a race there. I have a 8010 with 20 pd tranny. And I to worried about it when purchased. I have since stripped it of useless weight. No weights. No fluid. Removed extra fuel tank. Removed muffler under hood. Tractor pulls baler a lot nicer now and runs cooler. Love the 301 for fuel economy but like the old trucks got take your time and enjoy the day.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 11:49am
The only way you can put compressed air in to leak check is taking the rockers off so all the intake valves stay closed.
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2019 at 2:06pm
Run engine a high idle (wot) trans in park. Spray soapy water on all joints/questionable spots that could leak boost.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 8:48am
Well that was easy
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 9:49am
I'm thinking you have a big leak. That may just be a small leak. Seal it up and try it again on boost test.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 10:02am
I thought it was a little light too. No leaks around the crossover base or manifold. Figure if I fix that one it will put more pressure downstream.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 10:41am
All around the flange. So is it resealable?
Edited by exSW - 28 Jul 2019 at 10:44am
Fat albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fat albert Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 2:06pm
I don't know what Agco or Ed charge for that turbo. Butt Amazon has them for $360.00 shipped to your door.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 3:03pm
Been there done that got the Chinese turbo to prove it. I can buy a rebuild kit of all USA,UK or Canadian parts for $60.00 from a mid western Company. And keep my 100% Garrett core.
Edited by exSW - 28 Jul 2019 at 3:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 4:26pm
Replace the turbo. A rebuild kit is bearings and seals. Yours is so eroded, you'd waste so much time trying to get it apart. Looks like that would likely take care of your issue.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2019 at 8:49am
Not trying to start a fight. Just curious as I’ve never rebuilt a turbo. Did you perhaps rebuild your now 8010’s leaking turbo? How involved is a typical rebuild kit - shaft, shaft bushings, turbines, etc?? And if so, how many years service, per a rebuild kit?
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2019 at 10:40am
It's a 7010 but I believe the same turbo. But no I've never rebuilt one and I'm not sure I'm doing this one. Depends on tv wear and tear. Only reason I'm considering it is right now I have more time than money. And the local diesel shop has kits in stock. It will be a learning experience one way or the other. The kit is seals,bearings and some fasteners. As far as balance I'm going to index everything as it comes apart and go back together the same way.
[/QUOTE]
Not trying to start a eight. Just curious as I’ve never rebuilt a turbo. Did you perhaps rebuild your now 8010’s leaking turbo? How involved is a typical rebuild kit - shaft, shaft bushings, turbines, etc?? And if so, how many years service, per a rebuild kit?[/QUOTE]
Edited by exSW - 29 Jul 2019 at 10:46am
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2019 at 7:44pm
Edited by exSW - 07 Aug 2019 at 8:02pm
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 6:23pm
A GOOD rebuilder will replace not just the bearings and seals. They will replace impellers and housings if needed.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 7:01pm
I went with a new turbo. My reasoning was this.
1) less down time. Took me about four hours total. First one I've ever done.
2) Technical support. Ed answers the phone.
3) No core. So I can rebuild my original Garrett at my leasure and have a spare on the shelf for the next tractor.
