8010 power steering |
Post Reply |
Johnwilson_osf
Orange Level Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 930 |
Posted: 3 hours 57 minutes ago at 6:32pm |
Greetings all,
Hauling silage wagons with the 8010 this weekend, and started to have trouble steering. Tractor wanted to drift to the left, and was slow/unresponsive to turn back to the right. Eventually, I lost all steering to the right. Reading information on the forum here, someone had a similar problem with an 8030, and the likely culprit was the orbital steering motor at the end of the steering wheel. I am guessing, that after 9000 hours, a seal has blown, or some orifice is plugged, not allowing flow to the right turn valve. I see both used and new motors for sale online (Dealer, TractorParts ASAP, etc). I also see that there is a seal kit part number shown on the partsbook. If this is a seal issue, I can replace the seals for less than $100. If this is a bigger problem, the motor looks to be about $700 after the core charge is returned. What do you all recommend? Rebuilt, replace, or am I barking up the wrong tree of symptoms? Thank you John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
Orange Level Access Joined: 12 Sep 2009 Points: 20257 |
Re-seal the steering cylinder first. I suppose the leaf springs inside the steering control valve could be broken but I've never seen that yet. The other poster has never responded back.
Edited by DrAllis - 3 hours 50 minutes ago at 6:39pm |
Post Reply | |
