8000 series rear axle size
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series rear axle size
    Posted: 18 Jan 2017 at 2:11pm
Norm Swinford's book list all the rear axle sizes for the 7010-7080, but nothing for the 8010-8070. Reason I ask - I want to know which 70xx rear wheel centers will swap onto which 80xx? Is my follow guess close to right:
7010 & 8010 = 3.625" axle,
7030 (7040) & 8030 = 3.75" axle,
7050 (7060) & 8050 = 3.75" axle,
7080 & 8070 = 4.0"
I'm also assuming the 80xx may have similar 70xx long/ special axle options??
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 3:15pm
Just keep the original clamps with the tractor, center doesn't matter.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 3:58pm
Both the 7030 and 7050 are 3.625. I don't know if any other 7010 thru 8070 shared that axle size. And yes from what I've read here before you just need the correct wedges. The wheel hubs are all the same.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 4:00pm
Oh and if I remember right, the 7060 and possibly the 7045 and 8050 could be had with 4" long axles.
Wink
I am a Russian Bot
Arcs and Sparks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcs and Sparks Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 7:26pm
I believe that the 210. 220, 7010, 7020, 7030 and 7050 are all 3 5/8" ( 3.625" ) .  I know that the wedges I removed from a scrap 7050 replaced my pooched 220 wedges without issue.  There was a slight difference in the 7050 wedge design.  The 220 had all 3 holes in the "non key way" wedge tapped for the jack bolts and the key way wedge had none of the 3 holes tapped for the jack bolts.  The 7050 wedges had the outer 2 holes in each wedge half tapped for the jack bolts.  Using the jack bolts had equal success with both wedge designs.  I looked at a 7020 in the same boneyard but it's wedges were only a 2 hole in each wedge design.  The 7020 axle did measure 3.625" but I did not like that 2 hole design.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 8:46pm
the only way to KNOW what size axle was on a 7000 or 8000 is to measure them,,,
short axles, long axles and Mexican hat duals yielded different size axles installed to match the duals.  These units are at the age many wheels have been changed..
We have seen duals mounted with the wrong wedges...
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 11:12pm
Dealer lit. on the 8070's tells about 3-3/4" axles if it had FWA. Ours are 1985's and the have FWA and 4" rear axles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 8:49am
I appreicate your input. So there were changes thru the years.
A Jack bolt question - Is a Jack Bolt an item I need to purchase from a Dealer or can I use a similar sized grade 8 type?
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 9:43pm
The jacking bolts are a special thread so you will either need to get a set of have some made.
~Warren
This page was generated in 0.135 seconds.
