8000 Issues (Dr Allis) |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5604 |
![]() ![]() ![]() ![]() ![]() Posted: 16 May 2020 at 11:06pm |
The temp gauge needle went straight up and will not come down. I put on a new sending unit and still, it is at high noon. I also lost the rear work lights. Where is a good place to start checking for trouble.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22054 |
If the fuel gauge works, I'd guess it is the temp gauge itself. Would have to test wiring on the backside of the gauge to verify. Lights could be fuse or breaker depending on tractors age. Use Owners manual to see which style it has.
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2486 |
I'm no help for the temp gauge. Have you replaced the light switch? not sure if that would be your problem tho,,,I had some kind lighting issues with my 8010, there is an updated light switch/turn signal..
other than that,, well,, get a test light and start looking...corroded, dirty connecters can cause problems, burned out bulbs??
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Look behind the dash for pinched or melted wires causing a short
Thank you all. I HATE when the lights don't work.
Krazy Karl ![]() Silver Level ![]() ![]() Joined: 12 Sep 2011 Location: SE MN Points: 203 |
If you unplug the temp sensor the gauge should peg one way then if you ground the wire it should peg the other way. Way to see if your gauge and wiring is ok. But if get nothing then have to figure out wire or gauge
