72 all crop questions
plowboy8550 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Topic: 72 all crop questions
    Posted: 15 Apr 2012 at 7:46pm
I got my 72 home today, and I have a couple of questions. First it has set for a while and its a little tight, ive got it soaking and it does rock back and forth. I think its just tight chains and maybe a bearing ot two. Is there anything besides the normal to watch while trying to free it up? I would like to use it on small seeds like clover. Are the 72s as good or better than the 66 or 60s?
    Thanks for the help    matt
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 7:54pm
The only difference between a 72 and a 66 is it did away with the drapers up front to feed the cylinder and replaced them with a more "modern" auger and conveyer chain setup. The seperating area is all the same. I dont know what condition yours is in but if its kinda locked up it must have sat out in the weather. Even if bearings get free'd up will they be reliable for use?? Post afew pictures if you can. Ryan
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 11:12pm
Matt
I imagine the hold up is the fingers in the auger.  They can tighten up if exposed to the elements much.  Spray the fingers down well and maybe even unhook the drive chain and turn it over by hand.  Hope this helps.  I agree with Ryan, please post some pictures.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:51am
I still havent figured out the pics yet but im still trying. I am going to try it again in a couple of days but im sure i will have took start unhooking chains. Im also going to have to get a hy cyl to raise and lower the head. Sombody has robbed it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:46am
check under the false bottom where the clean grain raddle travels to be certain it's not full of nests or packed full of straw.Will destroy the raddle chain and slats
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:51am
If you need a new 7" auger I have an excellent one (very minimal use) for sale.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:45pm
Wish you were closer to Virginia Ken!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 1:03pm
It will ship!
This page was generated in 0.046 seconds.
